Sample not working.
1452
6
06-17-2011 06:33 AM
HemingZhu
derekswingley1
Looks like it's working for me. What specifically is not working for you?
HemingZhu
It does not show map on my IE 8 and could not add critical issue on my Goole Chrome 11.
derekswingley1
What are the errors your'e seeing?
HemingZhu
None errors not even warnings.
KellyHutchins
Esri Notable Contributor
It looks like there was a trailing comma at line 143. While some browsers (Chrome, Firefox) will ignore trailing commas IE does not. I've removed the comma and will update the sample as soon as possible.
 {'fieldName':'comment','label':'Comments','isEditable':true,'stringFieldOption':esri.dijit.AttributeInspector.STRING_FIELD_OPTION_TEXTAREA,}
Until the fixed version of the sample is ready you can run the code by removing the comma after STRING_FIELD_OPTION_TEXTAREA and the sample should run.
derekswingley1
Thanks Kelly!
