Sample Javascript Viewer
26491
72
05-27-2010 12:26 PM
ChristianSmith
Does anyone know if the sample viewer team plans to upgrade, change / modify the JS sample viewer in the near future ?
Smitty
NathanZgmm
Take a look here....
<html>
<body>
<script>
document.write("<h1>Nathan</h1>");
document.write("<p><h3>Subjects</p></h3>");
document.write("Math");
document.write("<p>50</p>");
document.write("English");
document.write("<p>70</p>");
document.write("Science" );
document.write("<p>75</p>");
document.write("Total Marks ");
first_value=100;
second_value=100;
third_value=100;
sumof=first_value+second_value+third_value;
document.write(sumof+"<br>");("Total Number");
document.write("Obtained Marks");
first_value=50;
second_value=65;
third_value=75;
document.write("Percentage");
first_value=175;
second_value=300;
third_value=100;
sumof=first_value/second_value*third_value;
document.write(sumof+"%");
alert("Press ok to Enter");
</script>
</body>
</html> Learn" rel="nofollow" target="_blank">http://www.funique.co.uk/bedroom-furniture/chest-of-drawers.ht... more here
JeffPace
Jeff, do you have code for the one that looks similar to flex viwer?
I do, but it was been customized after 2 years of development.  Iris's sample should be closer to "stock"
http://www.mymanatee.org/gisapps/mapviewer/ is our site.
Under the "?" there is a links widget.  This lets you load our site with a variety of config files.
NathanZgmm
Thanks for replying..
MarkPaulson
Great site! Love what you guys have done. Just getting started, but I'm going to plagiarize you look. I'm a little chapped at ESRI for the push on arcgis online and not providing the same support as they do for the online viewer.
JoshWhite
Honored Contributor
I'm a bit confused I tried out the basic viewer and I always get an error message.  I did what the template readme said and I always get the attached error.  I first tried it with my own webmap id and that didn't work so I used the one that came with the viewer and I still get the same error.
Josh White, AICP
Principal Planner
City of Arkansas City
JohnGravois
try adding the Url below at line 123 of the index.html
//Modify this to point to your sharing service URL if you are using the portal
sharingurl: "http://www.arcgis.com/sharing/content/items",
//specify a group in ArcGIS.com that contains the basemaps to display in the basemap gallery
MarkPaulson
Kelly, Where do you add  in the popup info and where is the 'createMap function'?
Ditto on this request. I'm a neophyte and I can't figure out where the basemap is coming from after I uploaded the sample viewer to my server.
Edit: finally figured that out, but when I try to make changes, I get the sign into ArcGIS online?
Edit: figured that out, I had my rest services locked with :-/. Now I only have to figure out the popups
JoshWhite
Honored Contributor
I did eventually find this in the readme document but it was under Specify map options.  It should be under configure the application right under #3 where it tells you to put in your webmap id.  I was just trying to make sure it worked before I tried to "specify map options".  Thanks for pointing this out to me.
Josh White, AICP
Principal Planner
JoshWhite
Honored Contributor
A new problem has come up for me.  I can't seem to pan on my Android smartphone.  I am able to zoom but not pan.  If I can't pan then there isn't much point in trying to develop a webmap for mobile.  I looked through the readme and can't find any mention of this.
PLEASE Esri, create a viewer that is configurable for Javascript and HTML5.
Also, I entered a URL for my geocoder and now the search box disappears.
We need more options for Mobile.  I have a field guy using ArcGIS for Android for now but it doesn't have many options.
Josh White, AICP
Principal Planner
KeG
esri should create a template viewer for js. and they should base it on html5boilerplate.
