RoutingTask Error 9004$LAYER_NOT_EXIST
4542
10-30-2015 09:29 AM
wcESRI
Hello,
I am attempting to solve a route.  My code is below.
To create my service, I added the following URL to my ArcGIS Online content.
I then made it accessible to everyone and used the REST URL in my code.
//prepare parameters
 var myRouteParams = new RouteParameters();
 myRouteParams.stops = new FeatureSet();
 myRouteParams.stops.features.push(myStartingGraphic);
 myRouteParams.stops.features.push(myEndingGraphic);
 myRouteParams.returnRoutes = true;
 myRouteParams.returnDirections = true;
 myRouteParams.outSpatialReference = new SpatialReference({ wkid:4326 });
 //perform route between addresses
 var myRouteTask = new RouteTask("url_goes_here");
 myRouteTask.solve(myRouteParams);
However, I get the following error in the debugger.
dojo.io.script error Error: 9004$LAYER_NOT_EXIST
"dojo.io.script error"
[object Error]{code: 500, description: "", details: Array[0], httpCode: 500, log: undefined, message: "9004$LAYER_...", name: "Error", number: 0}
What is causing this error?  Do I need something else in my routing parameters?
RickeyFight
Christopher,
When you try to browse to the layer you linked I get
wcESRI
I noticed that.  However, is something supposed to be listed?
I am also not sure what URL to use.
RickeyFight
Christopher,
You are right.
This example works with the same route layer you provided above.
Find a route | ArcGIS API for JavaScript
