Routing with polygon barriers not working Javascript API 4.24
1101
10-27-2022 02:49 PM
JS_GilbertAZ
I have routing set up in my web app and working, except when I try to add a rest feature service for polygonBarriers property of RouteParameters, it fails.  This is how I'm defining the polygonBarriers in the RouteParameters:
const routeParams = new RouteParameters({
stops: new FeatureSet({
features: view.graphics.toArray()
returnPolygonBarriers: true,
polygonBarriers: {
"url" : "https://maps.gilbertaz.gov/arcgis/rest/services/GilbertDays2022Closure/FeatureServer/1/query?where=1..."
The error I get is below.  I am pretty sure I am doing this the way the javascript API Reference show it, however I am not getting this to work.  I get this error in the console:
RouteParameters.js:5 Uncaught (in promise) TypeError: n.toJSON is not a function
at r (RouteParameters.js:5:156)
at f.writePolygonBarrier (RouteParameters.js:8:186)
at q ((index):263:421)
at a.write ((index):266:327)
at f.write ((index):254:370)
at f.toJSON ((index):254:420)
at e.routeParametersToQueryParameters (utils.js:5:115)
at Module.<anonymous> (route.js:6:98)
at Generator.next (<anonymous>)
at d ((index):35:26)
Thanks in advance for any assistance provided.  It may just be something minor that I'm overlooking, I've never worked with routing before...
JayakumarPD
I think stop is not understanding the parameters in new RouteParameters, I am also learning route.  Bellow is the code, which I have taken from ESRI and applied my API key.  How I can generate error, which you are getting.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Route | Sample | ArcGIS API for JavaScript 4.24</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #paneDiv {
        position: absolute;
        top: 10px;
        left: 62px;
        padding: 0 12px 0 12px;
        background-color: rgba(0, 0, 0, 0.5);
        color: white;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.24/"></script>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/Graphic",
        "esri/layers/GraphicsLayer",
        "esri/rest/route",
        "esri/rest/support/RouteParameters",
        "esri/rest/support/FeatureSet"
      ], function(Map, MapView, Graphic, GraphicsLayer, route, RouteParameters, FeatureSet) {
        // Point the URL to a valid routing service
        const routeUrl = "https://route-api.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World";
        // The stops and route result will be stored in this layer
        const routeLayer = new GraphicsLayer();
        // Setup the route parameters
          // An authorization string used to access the routing service
          apiKey: "MY-API-KEY",
// provide the array, to check
          stops: new FeatureSet(),
          outSpatialReference: {
            // autocasts as new SpatialReference()
            wkid: 3857
        // Define the symbology used to display the stops
        const stopSymbol = {
          type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
          style: "cross",
          outline: {
            // autocasts as new SimpleLineSymbol()
            width: 4
        // Define the symbology used to display the route
        const routeSymbol = {
          type: "simple-line", // autocasts as SimpleLineSymbol()
          color: [0, 0, 255, 0.5],
          width: 5
        const map = new Map({
          basemap: "streets-navigation-vector",
          layers: [routeLayer] // Add the route layer to the map
        const view = new MapView({
          container: "viewDiv", // Reference to the scene div created in step 5
          map: map, // Reference to the map object created before the scene
          center: [-117.195, 34.057],
          zoom: 13
        // Adds a graphic when the user clicks the map. If 2 or more points exist, route is solved.
        view.on("click", addStop);
        function addStop(event) {
          // Add a point at the location of the map click
          const stop = new Graphic({
            geometry: event.mapPoint,
            symbol: stopSymbol
          routeLayer.add(stop);
          // Execute the route if 2 or more stops are input
          routeParams.stops.features.push(stop);
          if (routeParams.stops.features.length >= 2) {
            route.solve(routeUrl, routeParams).then(showRoute);
        // Adds the solved route to the map as a graphic
        function showRoute(data) {
          const routeResult = data.routeResults[0].route;
          routeResult.symbol = routeSymbol;
          routeLayer.add(routeResult);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="paneDiv" class="esri-widget">
      <div>
        <p>
          Click on the map to add stops to the route. The route from the last stop to the newly added stop is
          calculated. If a stop is not reachable, then the last valid point is set as the starting point.
        </p>
      </div>
    </div>
  </body>
</html>
