Routing - road blocks
2321
03-09-2017 08:40 AM
by Anonymous User
Not applicable
Hi all,
I have points feature layer that represent road blocks. I would like to allow users to be using the direction widget to be rerouted. Is it possible?
Alex
RobertScheitlin__GISP
Alex,
  Sure, you would just have to add the features from your roadblock layer to the directions dijit using the esri private object called _barriersLayer
So it would look like:
var directions = new Directions({
  map: map
},"dir");
directions.startup();
directions._barriersLayer = yourBarriersLayer;
Alex,
  map: map
},"dir");
by Anonymous User
Not applicable
Cool, can this barrier layer be point (road blocks layer) or does it have to be a line feature.
Alex,
    That is for point layers there is a separate property for line and polygon barriers.
