RouteTask Closest Facility
1167
03-25-2014 09:08 AM
jaykapalczynski
Honored Contributor
Looking at this example and had a few questions.
https://developers.arcgis.com/javascript/jssamples/routetask_closest_facility.html
1.  I see that it is creating 5 square graphics to route against.  How do I add my own Service here
2.  I dont see how the routing is referencing the Square Graphics added (would like to change this to my own point feature)
3.  Is there anything else I would have to configure on my server?
4.  Do I need to create my own proxy?
urlUtils.addProxyRule({
        urlPrefix: "route.arcgis.com",
        proxyUrl: "/sproxy"
closestFacilityTask = new ClosestFacilityTask("http://route.arcgis.com/arcgis/rest/services/World/ClosestFacility/NAServer/ClosestFacility_World");
      registry.byId("numLocations").on("change", function() {
        params.defaultTargetFacilityCount = this.value;
        clearGraphics();
ManishkumarPatel
Hi Jay,
    The square graphics are being created using the symbols,
var incidentPointSymbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          16,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([89,95,35]), 2
          new Color([130,159,83,0.40])
For adding your own service you will have to publish a network analyst service.
Refer the below link for more details:
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000002pn000000
The square graphics that are added using the below line of code:
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13625960,4549921,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13626184,4549247,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13626477,4549415,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13625385,4549659,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13624374,4548254,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13624891,4548565,map.spatialReference)));
You can change this as per your requirement.
You can refer to the help document, if you face any issue while configuring the server.
You can configure your own proxy. Please refer to the below link:
https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
Hope this helps.
Regards,
Manish
jaykapalczynski
Honored Contributor
Thank you ... will get t his going... see how things go...will be in touch..
Thank you again...appreciated.
