route can't display in web
2876
08-06-2015 12:58 AM
daihere
Hi, all:
     Now,Im studying a function about shortest route and I encounter a problem.
     I released by arcmap successful network analyze service.
     When I try to generate any route, the route is not show in the graphic layer.
     When the code is debug to see where is the error, it does't show any problem, and looks all ok.
     Can someone give me and advice on where the problem can be???
     Here is the js code:
var editToolbar;
var currentLocation
require(["esri/map", "esri/geometry/Point", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/toolbars/draw", "esri/toolbars/edit",
  "esri/symbols/SimpleMarkerSymbol","esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol",
  "esri/symbols/PictureMarkerSymbol", "esri/graphic", "esri/geometry/jsonUtils", "esri/tasks/RouteTask", "esri/tasks/FeatureSet",
  "esri/tasks/RouteParameters", "esri/Color", "dojo/parser", "dijit/Menu",
  "dijit/MenuItem", "dijit/MenuSeparator", "dijit/form/Button",
  "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"],
  function (
  Map, Point, ArcGISDynamicMapServiceLayer, Draw, Edit, SimpleMarkerSymbol, SimpleLineSymbol,
  SimpleFillSymbol, PictureMarkerSymbol, Graphic, geometryJsonUtils, RouteTask, FeatureSet, RouteParameters, Color, parser, Menu,
  MenuItem, MenuSeparator
  var routes = [];
  var flag1, flag2 = false;
  var originPrve, pathwayPrve, endPrve;
  var graphic1, graphic2, graphic3;
  var flag = 0, x = 0, y = 0;
  var editToolbar;
  parser.parse();
  var map = new Map("mapDiv");
  map.setLevel(2);
  var url = "http://localhost:6080/arcgis/rest/services/china1/MapServer";
  var agoLayer = new ArcGISDynamicMapServiceLayer(url);
  // var agoLayer = new esri.layers.ArcGISTiledMapServiceLayer(url);
  map.addLayer(agoLayer);
  routeTask = new RouteTask("http://localhost:6080/arcgis/rest/services/ttt/NAServer/Route");
        routeParams = new RouteParameters();
        routeParams.stops = new FeatureSet();
        routeSymbol = new SimpleLineSymbol().setColor(new Color([255, 0, 0, 0.5])).setWidth(5);
        map.on("mouse-down", pointMove);
  map.on("load", createToolbarMenu);
  //使各个点移动结束后触发路径的再建立
  function pointMove (evt) {
  if (originPrve) {
  editToolbar.on("graphic-move-stop", function (originPrve) {
  var num = 0;
  clearRoutes();
  for (var i = routeParams.stops.features.length-1; i>=0; i--) {
  if (routeParams.stops.features.symbol.url === "originPoint.png") {
  num++;
  if (routeParams.stops.features.symbol.url === "endPoint.png") {
  num ++;
  if (num == 2){
  routeTask.solve(routeParams, showRoute, errorHandler);
  if (pathwayPrve) {
  editToolbar.on("graphic-move-stop", function (pathwayPrve) {
  var num = 0;
  clearRoutes();
  num++;
  num ++;
  if (num == 2){
  if (endPrve) {
  editToolbar.on("graphic-move-stop", function (endPrve) {
  var num = 0;
  clearRoutes();
  num++;
  num ++;
  if (num == 2){
  function createToolbarMenu () {
  editToolbar = new Edit(map);
  createMapMenu();
  function createMapMenu() {
  var ctMenuForMap = new Menu({
  onOpen: function (box) {
  currentLocation = getMapPointFromMenuPosition(box);
  ctMenuForMap.addChild(new MenuItem({
  label: "设为起点",
  onClick: function (evt) {//起点只 能有一个
  var num = 0;
  if (flag1) {
  routeParams.stops.features.splice(i, 1)[0];
  map.graphics.remove(originPrve)
  clearRoutes();
  var symbol = new PictureMarkerSymbol({
  "url": "originPoint.png",
  "height": 63,
  "width": 45,
  "type": "esriPMS"
  var graphic = new Graphic(geometryJsonUtils.fromJson(currentLocation.toJson()), symbol);
  routeParams.stops.features.push(
  map.graphics.add(graphic)
  originPrve = graphic;
  editToolbar.activate(Edit.MOVE, originPrve);
  flag1 = true;
  //只有在起点和终点都设立之后才可以生成路径
  num++;
  num ++;
  if (num == 2){
  ctMenuForMap.addChild(menuItem = new MenuItem({
  label: "设为途径点",
  var num = 0;
  flag ++; //falg为全局变量,目的是控制途径点的个数
  var symbol;
  clearRoutes();
  "width": 45,
  "height": 69,
  "type": "esriPMS"
  switch (flag) {
  case 1:
  symbol.url = "pathwayPoint1.png";
  break;
  case 2:
  symbol.url = "pathwayPoint2.png";
  break;
  case 3:
  symbol.url = "pathwayPoint3.png";
  break;
  case 4:
  symbol.url = "pathwayPoint4.png";
  break;
  case 5:
  symbol.url = "pathwayPoint5.png";
  menuItem.disabled = true;
  break;
  editToolbar.activate(Edit.MOVE, graphic);
  pathwayPrve = graphic;
  num++;
  num ++;
  if (num == 2){
  label: "设为终点",
  var num = 0;
  if (flag2) {//终点只能有一个
  map.graphics.remove(endPrve)
  clearRoutes();
  "url": "endPoint.png",
  "width": 45,
  "height": 61,
  "type": "esriPMS"
  endPrve = graphic;
  flag2 = true;
  num++;
  num ++;
  if (num == 2){
  ctMenuForMap.startup();
  ctMenuForMap.bindDomNode(map.container);
  function getMapPointFromMenuPosition (box) {
  var x = box.x, y = box.y;
  var screenPoint = new Point(x - map.position.x, y - map.position.y);
  return map.toMap(screenPoint);
  function showRoute (result) {
  var routeResults = result.routeResults;
  routes.push(
  map.graphics.add(routeResults[0].route.setSymbol(routeSymbol))
  console.log(routeResults[0].route.setSymbol(routeSymbol));
  var msgs = ["服务器消息:"];
     for (var i = 0; i < result.messages.length; i++) {
         msgs.push(result.messages.type + " : " + result.messages.description);
     if (msgs.length > 1) {
         alert(msgs.join("\n - "));
  function clearRoutes() {
    for (var i = routes.length - 1; i >= 0; i--) {
        map.graphics.remove(routes.splice(i, 1)[0]);
    routes = [];
  function errorHandler(err) {
    alert("发生错误\n" + err.message + "\n" + err.details.join("\n"));
daihere
daihere
When I use another  routeTask url (that was published long time ago), route can be created.
daihere
I don't know why use new url (that is new publish in arcmap) can't show the route in the map.
So, I need your help~
RobertScheitlin__GISP
Dai,
   Was your ArcGIS Server upgraded and the new service is running on a different version of AGS then the old service was? What line does the undefined error point to?
