ROTATE infoWindow
1734
03-23-2012 06:27 AM
CliveSwan
I need to display the infoWindow portrait if less than 5 records AND landscape if more than 5 records.
Getting getinfoWinTabContainer error, details: [object error]
Code:
map.infoWindow.setTitle("Identify Results");
                //map.infoWindow.setContent(tc.domNode);
                if( (theLayerName != "Underground") && (idResults.length  == 1) )
   // alert("1 record");
   map.infoWindow.resize(360, 200);
  else if ( (theLayerName != "Underground") && (idResults.length  > 1) )
                   // alert("> 1 record");
     map.infoWindow.resize(900, 425);
                 map.infoWindow.orientation == 270;
                 // tc = tcLarge;
KenDoman
Do you want to turn your infoWindow results sideways? Or do you want your infoWindow to be wider when there are more results?
There is no "orientation" parameter for map.infoWindow. But for resize, the first number is width, and the second number is height. I would try flipping the numbers with resize to get the landscape/portrait effect. Here's some of your code modified.
if( (theLayerName != "Underground") && (idResults.length < 5) )
// alert("less than 5 records");
map.infoWindow.resize(200, 360); // narrower for less records
else if ( (theLayerName != "Underground") && (idResults.length >= 5) )
// alert(">= 5 records");
map.infoWindow.resize(360, 200); // wider for more records
// map.infoWindow.orientation == 270; <- use = instead of == to set variable. This was causing your error.
// tc = tcLarge;
CliveSwan
Hi Raymond,
Thanks for the email. Replacing (map.infoWindow.orientation == 270;) with map.infoWindow.orientation = 270;
Got rid of the error message. However it has not changed the infoWindow orientation??
Is there anything that I am missing??
KenDoman
There's no orientation in map.infoWindow that I can find. The closest thing I can find so far is a CSS3 transform which might work (if you're supporting a newer browser like firefox, chrome, or IE9).
For the following to your css.
.rotated270
transform:rotate(270deg);
-ms-transform:rotate(270deg); /* IE 9 */
-moz-transform:rotate(270deg); /* Firefox */
-webkit-transform:rotate(270deg); /* Safari and Chrome */
-o-transform:rotate(270deg); /* Opera */
Then, in your JavaScript, try this.
dojo.query(".infowindow").removeClass("rotated270");
dojo.query(".infowindow").addClass("rotated270");
// tc = tcLarge;
