Reversegeocoding
1607
06-06-2019 11:55 PM
SergeDe_Backer
I have a project which uses the Belgium geolocator to search for the adresses. This works, but when I want to reversegeocode I get in trouble
The url for the search should be this format: http://loc.geopunt.be/geolocation/location?latlon=51.03868741989108,3.7066240164852555&c=1
But the locator always adds a lot of other params with it and I can't find a way to get it working.
Any help is appreciated.
This is my code so far:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Search widget with custom source - 4.11</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet"
href="https://js.arcgis.com/4.11/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.11/"></script>
<script>
require([
"esri/tasks/Locator",
"esri/Map",
"esri/Graphic",
"esri/request",
"esri/views/MapView",
"esri/widgets/Search",
"esri/widgets/Search/SearchSource",
"esri/geometry/geometryEngine",
"esri/geometry/Point",
"esri/layers/WMSLayer"
], function (
Locator,
Map,
Graphic,
esriRequest,
MapView,
Search,
SearchSource,
geometryEngine,
Point,
WMSLayer
var url = "https://loc.api.geopunt.be/geolocation/location?c=5",
layer = new WMSLayer({
url: 'https://geoservices.informatievlaanderen.be/raadpleegdiensten/GRB-basiskaart/wms'
var map = new Map({
basemap: "streets"
map.add(layer);
var view = new MapView({
map: map,
zoom: 8,
center: [4.402771, 51.260197], //lon, lat
container: "viewDiv"
var customSearchSource = new SearchSource({
name: "Vlaanderen zoekopdracht",
placeholder: "Geef je straatnaam in",
displayField: "name",
// Provide a getSuggestions method
// to provide suggestions to the Search widget
getSuggestions: function (params) {
// You can request data from a
// third-party source to find some
// suggestions with provided suggestTerm
// the user types in the Search widget
return esriRequest(url, {
query: {
q: params.suggestTerm
responseType: "json"
}).then(function (results) {
// Return Suggestion results to display
// in the Search widget
return results.data.LocationResult.map(function (item) {
return {
key: "name",
text: item.FormattedAddress,
sourceIndex: params.sourceIndex
// Provide a getResults method to find
// results from the suggestions
getResults: function (params) {
// If the Search widget passes the current location,
// you can use this in your own custom source
var operation = "&q=" + params.suggestResult.text.replace(/ /g, "+");
var query = {};
// You can perform a different query if a location
// is provided
if (params.location) {
query.lat = params.location.latitude;
query.lon = params.location.longitude;
} else {
query.q = params.suggestResult.text.replace(/ /g, "+");
return esriRequest(url + operation, {
query: query,
// Parse the results of your custom search
var searchResults = results.data.LocationResult.map(function (feature) {
// Create a Graphic the Search widget can display
var graphic = new Graphic({
geometry: new Point({
x: feature.Location.Lon_WGS84,
y: feature.Location.Lat_WGS84
attributes: feature
// Optionally, you can provide an extent for
// a point result, so the view can zoom to it
var buffer = geometryEngine.geodesicBuffer(
graphic.geometry,
50,
"meters"
// Return a Search Result
var searchResult = {
extent: buffer.extent,
feature: graphic,
return searchResult;
// Return an array of Search Results
return searchResults;
// Create Search widget using custom SearchSource
var searchWidget = new Search({
view: view,
sources: [customSearchSource],
includeDefaultSources: false
view.on("click", function (event) {
console.log(event.mapPoint.latitude + "," + event.mapPoint.longitude);
// Haal de co�rdinaten van het aangeklikte punt op
var rdx = Math.round(event.mapPoint.x);
var rdy = Math.round(event.mapPoint.y);
view.popup.open({
// Toon de gevonden RD co�rdinaten in de titel van de popup. De co�rdinaten worden
// afgerond op hele meters en er wordt een punt geplaatst tussen de duizendtallen
//title: "RD Coordinaten: X = " + rdx.toLocaleString() + " / Y = " + rdy.toLocaleString(),
location: event.mapPoint // Plaats de popup op de aangeklikte locatie
var locatorTask = new Locator({
url: "https://loc.api.geopunt.be/geolocation/location?&latlon=" + event.mapPoint.latitude + "," + event.mapPoint.longitude,
// Toon de popup
// Voer reverse geocoding uit voor de aangeklikte locatie
locatorTask
.locationToAddress(event.mapPoint)
.then(function (response) {
// Toon het gevonden adres in de popup
view.popup.content = response.address;
.catch(function (error) {
console.log(error);
// Toon een foutmelding als er geen adres gevonden wordt
view.popup.content = "Er is geen adres gevonden voor deze locatie";
// Add the search widget to the top left corner of the view
view.ui.add(searchWidget, {
position: "top-right"
});</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Serge,
   The Locator class is for use with esri locators services. So you have to do the location request manually. Here is your code modified for that:
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.11/esri/themes/light/main.css" />
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
      "esri/request",
    ], function (
      Map,
      Graphic,
      esriRequest,
      MapView,
      Search,
      SearchSource,
      geometryEngine,
      Point,
      WMSLayer
      var url = "https://loc.api.geopunt.be/geolocation/location",
      var map = new Map({
        basemap: "streets"
      map.add(layer);
        map: map,
        zoom: 8,
            query: {
              return {
                key: "name",
          var query = {};
          // is provided
          } else {
            query: query,
                attributes: feature
                graphic.geometry,
                50,
                "meters"
                feature: graphic,
        view: view,
        view.popup.clear();
        view.popup.content = "Geocoding location...";
        view.popup.open({
        esriRequest(url, {
            query: "latlon=" + event.mapPoint.latitude + "," +
            var frslt = results.data.LocationResult[0];
            console.info(frslt);
            view.popup.content = frslt.FormattedAddress;
            view.popup.title = frslt.Location.Lat_WGS84 + ", " + frslt.Location.Lon_WGS84
  </script>
</head>
<body>
</body>
</html>
Serge,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
      "esri/request",
    ], function (
      Map,
      Graphic,
      esriRequest,
      MapView,
      Search,
      SearchSource,
      geometryEngine,
      Point,
      WMSLayer
      var map = new Map({
        basemap: "streets"
      map.add(layer);
        map: map,
        zoom: 8,
            query: {
              return {
                key: "name",
          var query = {};
          // is provided
          } else {
            query: query,
                attributes: feature
                graphic.geometry,
                50,
                "meters"
                feature: graphic,
        view: view,
        view.popup.clear();
        view.popup.open({
        esriRequest(url, {
  </script>
</head>
<body>
</body>
</html>
SergeDe_Backer
Thanks Robert, spot on.
