reverse geocode doesnt update the box(Directions widget). Clicking to add a point also adds at coordinates instead of address
3416
10-20-2015 04:24 AM
lasinh
i used The Directions widget arcgis api javascript, but when i click on map,  reverse geocode doesnt update the box(Directions widget), Clicking to add a point also adds at coordinates instead of address. (I am using my own geocoding, geometry and routing services) .how to update address to box? thank you;
my code:
<!DOCTYPE html>
<html>
  <head>
    <title>Directions Widget</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      require([
        "esri/urlUtils", "esri/map", "esri/dijit/Search",  "esri/tasks/locator", "esri/dijit/Directions",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        urlUtils, Map, Search,  Locator,  Directions,
        parser
        parser.parse();
        //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
        var strPathService = "http://115.79.20.1:6080/arcgis/rest/services/";
          map = new Map("map", {
              zoom: 6,
          var tiled = new esri.layers.ArcGISDynamicMapServiceLayer(strPathService + "Bandochuyende/numberhouse/MapServer");
          map.addLayer(tiled);
        //travelModesServiceUrl option points to logistics service hosted from ArcGIS Online
        //by indicating this URL, a login prompt should not display
        var directions = new Directions({
          map: map,
           mapClickActive: true,
          searchOptions: {
             sources: [
               locator: new Locator(strPathService + "Geocode/GEOCODING_SONHA_BH/GeocodeServer"),
                     name: "Custom Geocoding Service",
                     localSearchOptions: {
                     minScale: 3000000,
                       distance: 500000
                     placeholder: "Search Geocoder",
                     maxResults: 3,
                     maxSuggestions: 6,
                     enableSuggestions: false,
                     minCharacters: 0
          //travelModesServiceUrl: "http://utility.arcgis.com/usrsvcs/servers/cdc3efd03ddd4721b99adce219629489/rest/services/World/Utili...",
       routeTaskUrl: strPathService + "NetworkRouter/network01102015/NAServer/Route"
        },"dir");
        directions.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
TyroneBiggums
Note the use of location-to-address-complete here:
https://developers.arcgis.com/javascript/jssamples/locator_reverse.html
lasinh
thanks repply!! usinguse location-to-address-complete updated list of stops or not? how to update stops box directions widget?
TyroneBiggums
Full disclosure, I'm not familiar with the directions widget. I've only used aspects of it. Once a location for A and B was entered, the up/down arrow button switches A and B. Other than that, I don't know about updating the stops/addresses.
The link that I provided is for taking the coordinates that are showing up for A and B on the reverse geocoder, and providing an address. I only addressed that part of your question.
If you tell me what you mean by updating stops, I might be able to take a peak later.
lasinh
i used location-to-address-complete get address to box, but My code does not work as expected, please help me, thank you!!!
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        overflow:hidden;
    </style>
    <script>
        require([
        "esri/urlUtils", "esri/map", "esri/dijit/Search", "esri/graphic", "esri/Color",
        "esri/InfoTemplate", "esri/geometry/webMercatorUtils", "esri/tasks/locator", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/dijit/Directions",
        "dojo/parser",
      ], function (
        urlUtils, Map, Search, Graphic, Color, InfoTemplate, webMercatorUtils, Locator, SimpleMarkerSymbol, SimpleLineSymbol, Directions,
        parser
          parser.parse();
              zoom: 6
          var infoTemplate = new InfoTemplate("Location", "Address: ${Street}");
          var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          15,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([0, 0, 255, 0.5]),
            8
          new Color([0, 0, 255])
          var locator = new Locator(strPathService + "Geocode/GEOCODING_SONHA_BH/GeocodeServer");
              map: map,
              searchOptions: {
                  sources: [
                   locator: locator,
                       minScale: 3000000,
                       distance: 500000
                   maxResults: 3,
                   maxSuggestions: 6,
                   minCharacters: 0
          }, "dir");
          locator.on("location-to-address-complete", function (evt) {
              if (evt.address.address) {
                  var address = evt.address.address;
                  var location = evt.address.location;
                  //this service returns geocoding results in geographic - convert to web mercator to display on map
                  // var location = webMercatorUtils.geographicToWebMercator(evt.location);
                  var graphic = new Graphic(location, symbol, address, infoTemplate);
                  map.graphics.add(graphic);
                  for (var i = 0; i <= directions.stops.length - 1; i++) {
                      directions.stops.name = evt.address.address.Street;
                  map.infoWindow.setTitle(graphic.getTitle());
                  map.infoWindow.setContent(graphic.getContent());
                  //display the info window with the address information
                  var screenPnt = map.toScreen(location);
                  map.infoWindow.resize(200, 100);
                  map.infoWindow.show(screenPnt, map.getInfoWindowAnchor(screenPnt));
          map.on("click", function (evt) {
              map.graphics.clear();
              locator.locationToAddress(evt.mapPoint, 100);
    </script>
  </head>
      </div>
      <div id="map"
      </div>
    </div>
  </body>
</html>
