Return Value as a Link
1489
07-17-2012 12:43 PM
CraigMcDade
Working with the Identify - Popup sample code
Is there a way to configure the returned value as a link?
Example:
var template = new esri.InfoTemplate("",
    "<b>Station:</b> ${Corner Point Identifier}");
I'd like the Corner Point Identifier to be returned as a link to its individual file.
All the files have the same path except for the Corner Point Identifier + .pdf
Is this possible?
AustinDavis
Will coding the return into an anchor tag work?
'<b>Station:</b><a href="http://'+ ${Corner Point Identifier}+'.pdf>Descriptive Text</a>"
CraigMcDade
No, when I edit the code like that it fails the entire map and nothing starts.
AustinDavis
Reading through some of the API, this may work:
var infoTemplate = new esri.InfoTemplate();
infoTemplate.setContent( '<b>Station:</b><a href="http://${Corner Point Identifier}.pdf">Descriptive Text</a>' );
If this is a valid path:
CraigMcDade
well that seems to be closer. Now the map draws and the popup comes up, however, it is empty and shows "no information available".
I've tried using similar sample code as located in the "Info Window Lite" sample, however that doesn't work for this either.
I appreciate your help!
CraigMcDade
Update:
I can construct the url using:
    "<b>Station:</b> http://gisdev2/surveybenchmarks/scans/${Corner Point Identifier}.pdf" ) ;
This populates the popup with the http://.....pdf string
However, the map fails when I try to use the html link constructors.
