Retrieve feature attributes uid/dictionary values
1255
11-27-2023 03:14 PM
patryks
My requirement is to export features attributes to CSV file. In Feature Table widget the dictionary attributes are properly visualized - with dictionary value. In graphic object the attributes contains only uids like:
species_id: "b96c54b0-1b79-4a8b-af07-06b60a85b959"
status_id: "d6acca47-4c88-4da1-9e17-8c8b5d54f7f7"
How can I access the corresponding dictionary value?
ViktorSafar
This is very hard to help, show some code?
Feature/Graphic objects have property "attributes" which then have properties named after the attributes.
eg:
  • myObject.attributes.name
  • myObject.attributes.address
  • myObject.attributes.GlobalId
  • myObject.attributes.ObjectId
patryks
This is the graphic attributes object I can access in javascript:
objectid: 1,
species_id: "b96c54b0-1b79-4a8b-af07-06b60a85b959",
species_id is coded value that have more that 4k values
This is how it is visualized in FeatureTable
FeatureTable can access coded/dictionary value of the attribute. Is there a way to access it via js api?
