Retrieval of latitude/longitude when Locate button clicked
5288
14
08-09-2023 11:25 AM
DavidShearan
I have inherited a website from another developer but I am new to arcgis and esri. One of the functions of the site is to record butterfly sightings in Corfu. The PHP script has two input fields 'rLatitude' and 'rLongitude' which are populated when a user clicks on the displayed map. The map also has a Locate button to get the user's current location - when clicked it zooms in and displays the current location but it does not populate the two fields. That is what I am trying to achieve.
Please could someone advise what extra coding I need in order to achieve my objective.
Many thanks in advance
The full script (with the exception of the Corfu polygon) is as follows:
<script src="https://js.arcgis.com/4.22/"></script>
<script>
//LOAD LAYERS
require([
"esri/tasks/Locator",
"esri/Map",
"esri/views/MapView",
"esri/Graphic",
"esri/layers/GraphicsLayer",
"esri/widgets/BasemapToggle",
"esri/widgets/BasemapGallery",
"esri/widgets/Locate",
"esri/widgets/Home",
"esri/widgets/Compass"
], function(Locator, Map, MapView, Graphic, GraphicsLayer, BasemapToggle, BasemapGallery, Locate, Home, Compass) {
// SET UP LOCATOR TASK USING WORLD GEOCODE SERVER
var locatorTask = new Locator({
url: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
//LOAD INITIAL BASE LAYER TYPE
var map = new Map({
basemap: "topo-vector"
//LOCATE MAP CENTER AND ZOOM LEVEL
var view = new MapView({
container: "viewDiv",
map: map,
center: [19.874268, 39.576056], // longitude, latitude
zoom: 10
* This click event sets generic content on the popup not tied to
* a layer, graphic, or popupTemplate. The location of the point is
* used as input to a reverse geocode method and the resulting
* address is printed to the popup content.
view.popup.autoOpenEnabled = false;
view.on("click", function(event) {
// Get the coordinates of the click on the view
var lat = Math.round(event.mapPoint.latitude * 1000000) / 1000000;
var lon = Math.round(event.mapPoint.longitude * 1000000) / 1000000;
view.popup.open({
// Set the popup's title to the coordinates of the location
title: "<strong>Location coordinates:</strong><br><br><strong>Latitude:</strong> " + lat + "<br><strong>Longitude:</strong> " + lon + "",
location: event.mapPoint // Set the location of the popup to the clicked location
var params = {
// Update the form fields
$('#rLatitude').val(lat);
$('#rLongitude').val(lon);
graphicsLayer.removeAll();
var point = {
type: "point",
latitude: lat,
longitude: lon
//FORMAT RECORD POINT STYLE
var simpleMarkerSymbol = {
type: "simple-marker",
color: [220, 53, 69, 1], // orange
outline: {
color: [255, 255, 255, 1], // white
width: 2
var pointGraphic = new Graphic({
geometry: point,
symbol: simpleMarkerSymbol
graphicsLayer.add(pointGraphic);
view.on("Locate", function(event) {
view.popup.open({
var params = {
var point = {
type: "point",
latitude: lat,
longitude: lon
outline: {
width: 2
geometry: point,
//TOGGLE LOCATE BUTTON
var locateBtn = new Locate({
view: view
//TOGGLE HOME BUTTON
var homeBtn = new Home({
view: view
//TOGGLE COMPASS BUTTON
var compassWidget = new Compass({
view: view
//TOGGLE BASE LAYER TYPE
var basemapToggle = new BasemapToggle({
view: view,
nextBasemap: "satellite"
//POSITION BASE LAYER TOGGLE
view.ui.add(basemapToggle, "bottom-left");
var graphicsLayer = new GraphicsLayer();
map.add(graphicsLayer);
<?php
* Only add the marker if lat long set (breaks add record otherwise)
if(isset($rLatitude) && isset($rLongitude)) :
//POSITION RECORD POINT
var point = {
type: "point",
latitude: <?= $rLatitude ?>,
longitude: <?= $rLongitude ?>
outline: {
width: 2
geometry: point,
<?php
endif;
var simpleFillSymbol = {
type: "simple-fill",
color: [0, 190, 90, 0.025], // CBC Green, opacity 2.5%
outline: {
color: [0, 190, 90, 1],
width: 1
var polygonGraphic = new Graphic({
geometry: polygon,
symbol: simpleFillSymbol
graphicsLayer.add(polygonGraphic);
//LOAD AND FORMAT CO-ORDINATE WIDGET TO DISPLAY LAT/LON, SCALE AND ZOOM LEVEL
var coordsWidget = document.createElement("div");
coordsWidget.id = "coordsWidget";
coordsWidget.className = "esri-widget esri-component";
coordsWidget.style.padding = "7px 15px 5px";
view.ui.add(coordsWidget, "bottom-right");
function showCoordinates(pt) {
var coords =
"Latitude " +
pt.latitude.toFixed(6) +
" | Longitude " +
pt.longitude.toFixed(6) +
" | Scale 1:" +
Math.round(view.scale * 1) / 1 +
" | Zoom " +
view.zoom;
coordsWidget.innerHTML = coords;
view.watch("stationary", function(isStationary) {
showCoordinates(view.center);
view.on("pointer-move", function(evt) {
showCoordinates(view.toMap({
x: evt.x,
y: evt.y
// ADD THE LOCATE BUTTON
view.ui.add(locateBtn, {
position: "top-left"
// ADD THE HOME BUTTON
view.ui.add(homeBtn, "top-left");
// ADD THE COMPASS WIDGET BUTTON
view.ui.add(compassWidget, "top-left");
</script>
JoelBennett
MVP Regular Contributor
A good place to start would probably be the browser's developer tools (F12 or Ctrl-Shift-I)...do you see any error messages that get produced for this workflow?
DavidShearan
Yes I checked there. No errors, just some warnings about cookies
JoelBennett
You might also add this to see if it produces an error message:
locateBtn.on("locate-error", function(evt) {
	alert(evt.error.message);
DavidShearan
Thanks again Joel but I no longer have the issue.
I woke in the middle of the night with the sudden realisation that I had used FTP to upload the calling PHP script and not the included Javascript code! doh
So at about 5am I fired up the laptop, used my FTP program to upload the .js file and hey presto.
Sorry, it was a schoolboy error but I am still thrilled that it now works, thanks to you
JoelBennett
It's amazing how many realizations occur at that time of day/night!
