Resource proxy Url not pre-pending to request Url (4x)
3298
8
10-02-2019 10:47 AM
DirkVandervoort
Below is simple code to add a secure webmap into a MapView. This issue is that the proxy URL in not pre-pending to the Portal item URL. Instead I get the login dialog.
I expect to see a URL like this in my network traffic:
https://MY_PROXY_URL/EsriResourceProxy/proxy.ashx?https://MY_PORTAL_URL/portal/sharing/rest/content/... which successfully returns content in the browser. This indicates that the proxy is properly configured and the values in proxy.config are correct.
Instead, I see native URLs like this in my network traffic:
https://MY_PORTAL_URL/portal/sharing/rest/content/items/4b0a97623245423fb3cbdfb321f0970e which informs me that I do not have permissions.
So, my question is: how do I get my JS to format the request Url to be pre-pended with the proxy URL?
TIA
<script>
 require([
 "esri/views/MapView",
 "esri/WebMap",
 "esri/config"],
 function(
 MapView,
 WebMap,
 esriConfig) {
esriConfig.request.proxyUrl = "https://MY_PROXY_DOMAIN/EsriResourceProxy/proxy.ashx";
 esriConfig.portalUrl = "https://MY_PORTAL_DOMAIN/portal";
 var webmap = new WebMap({
 portalItem: {
 var view = new MapView({
 map: webmap,
 container: "viewDiv"
 </script>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
BenElan
Esri Alum
Try adding it as a proxy rule. In the JavaScript app:
urlUtils.addProxyRule({
   urlPrefix: "https://MY_PORTAL_DOMAIN/portal",
   proxyUrl: "https://MY_PROXY_DOMAIN/EsriResourceProxy/proxy.ashx"
In proxy.config:
<serverUrl url="https://MY_PORTAL_DOMAIN/portal"
    username="USERNAME"
    password="PASSWORD"
    matchAll="true"/>‍‍‍‍
Relevant documentation:
Setting up proxy overview
addProxyRule
DirkVandervoort
I tried that as well without success. No joy...
BenElan
Esri Alum
In your browser, when you go to:
https://MY_PROXY_DOMAIN/EsriResourceProxy/proxy.ashx?ping
You should get an output like:
{ "Proxy Version": "1.1.2", "Configuration File": "OK", "Log File": "Not Exist/Readable"}
If your proxy is set up correctly. Can you check that?
DirkVandervoort
Yes, pinging the proxy returns the expected results. The proxy is configured correctly. Thanks.
BenElan
Esri Alum
Are there any errors in the console or network traffic in the browser's dev tools?
DirkVandervoort
No errors in console or in network traffic.
esriConfig.request.proxyUrl and urlUtils.getProxyUrl() both have values i.e., the proxy URL after the proxyUrl has been set
BenElan
Esri Alum
I'd suggest opening a case with Esri Technical Support so an Analyst can take a closer look.
JackFanZhang
I had the same issue, in my case, I solved it by using urlUtils.addProxyRule instead of push the rules directly to the esriConfig.requst.proxyRules, this is the way suggested by the API doc
   proxyUrl: "https://localhost:8080/proxy",
   urlPrefix: "https://myportaldomain/arcgis/sharing"
