Resize Googel Map
3197
09-20-2015 09:53 AM
JulieBiju
Hi All,Thank u for ur time
The following is the javascript I am using to load google and esri map
Here I am planning to use google map with free of cost with size  width < 640 and height < 640 .In this case how can I resize only googlemap when user click on google map button?Help [plssssss
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Map.aspx.vb" Inherits="Default2" %>
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
    <head runat="server">
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
        <meta http-equiv="X-UA-Compatible" content="IE=7" />
        <!--The viewport meta tag is used to improve the presentation and behavior of the samples
        on iOS devices-->
        <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
        <title>Google Maps Layer in ArcGIS JS API</title>
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css"/>
    <style type="text/css">
        html, body, #mapDiv{
        padding: 0;
        margin: 0;
        height: 100%;
            z-index: -1;
        .auto-style3 {
            height: 20px;
        .auto-style6 {
            height: 2%;
            width: 279px;
        .auto-style7 {
            width: 279px;
        #TxtAltareeqEng {
            width: 55px;
        #TxtAltareeqEng0 {
            width: 55px;
    </style>
     <script type="text/javascript">
         var djConfig = {
             parseOnLoad: true,
             baseUrl: './',
             modulePaths: {
                 // if use local copy, make sure the path reference is relative to 'baseUrl', e.g.:
                 //'agsjs': '../build/agsjs'
                 // use absolute path for online version. Note sometimes googlecode.com can be slow.
                 'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/1.05/build/agsjs'
        </script>
        <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4">
        </script>
         <script type="text/javascript" src="Scripts/gmapslayer_compiled.js">
        </script>
        <script src="Scripts/jquery-2.1.1.js" type="text/javascript"></script>
            window.onerror = function (msg, url, linenumber) {
                alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
                return true;
            dojo.require("esri.map");
            dojo.require("dijit.form.Button");
            dojo.require("dijit.layout.BorderContainer");
            dojo.require("dijit.layout.ContentPane");
            //dojo.require("agsjs.layers.GoogleMapsLayer");
            dojo.require("esri.layers.graphics");
            dojo.require("esri.virtualearth.VETiledLayer");
            var map;
            var streetMap, esriTopo, gMap, BingLayer;
            var graphicsLayer;
            var Map1, Map2;
            var lastposdate  = "";
            var DoorOpenClose = 'NO';
            function init() {
                var initExtent = new esri.geometry.Extent({
                    "xmin": -14628212,
                    "ymin": 714227,
                    "xmax": 7718305,
                    "ymax": 9832858,
                    "spatialReference": {
                        "wkid": 102100
                //alert('init');
                map = new esri.Map("mapDiv", {
                    extent: initExtent,
                    logo: true
                Map1 = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
                Map2 = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServ...";
                streetMap = new esri.layers.ArcGISDynamicMapServiceLayer(Map1, {
                map.addLayer(streetMap);
                esriTopo = initLayer(Map2, "esriTopo");
                BingLayer = new esri.virtualearth.VETiledLayer({
                    bingMapsKey: "A......",
                    mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
                map.addLayer(BingLayer);
                gMap = new gmaps.GoogleMapsLayer({
                    visible: false,
                map.addLayer(gMap);
                graphicsLayer = new esri.layers.GraphicsLayer();
                map.addLayer(graphicsLayer);
                var resizeTimer;
                dojo.connect(map, 'onLoad', function (theMap) {
                    dojo.connect(dijit.byId('map'), 'resize', function ()
                    { //resize the map if the div is resized
                        clearTimeout(resizeTimer);
                        resizeTimer = setTimeout(function () {
                            map.resize();
                            map.reposition();
                        }, 500);
            function initLayer(url, id) {
                var layer = new esri.layers.ArcGISDynamicMapServiceLayer(url, {
                    visible: false
                map.addLayer(layer);
              return layer;
            function changeMap(layers) {
                hideImageTiledLayers(layers);
                for (var i = 0; i < layers.length; i++) {
                    layers.show();
                    alert(layers.id);
            function hideImageTiledLayers(layers) {
                  for (var j = 0, jl = map.layerIds.length; j < jl; j++) {
                    var layer = map.getLayer(map.layerIds);
                    if (dojo.indexOf(layers, layer) == -1) {
                        layer.hide();
                dojo.addOnLoad(init)
        </script>
</head>
<body class="claro"  >
<form id="form1" runat="server">
    <div style="width: 100%; height: 100%">
                <table id="Tablecontrols0"   style="font-size: 15px; z-index: 101;
            background-color: #5B748B; width: 100%; height: 100%;">
            <tr style="font-family: Times New Roman">
                <td style="border-style: none; background-color: #496277; "
                    valign="top" class="auto-style6" >
                     </td>
                <td align="left"   style="border-style: none; background-color: #496277; height: 2%;"
                    valign="top" class="auto-style3" >
                     </td>
            </tr>
                <td style="border-style: none;"
                    valign="top" bgcolor="#496277"   >
                     </td>
                <td style="border-style: none; background-color: white; height: 500px;"
                    valign="top" id="td11" >
            <div id="mapDiv" runat ="server"  dojotype="dijit.layout.ContentPane" region="center"
                style="border:1px solid #000; visibility: visible; height: 100%; ">
                <br />
                <br />
            </div>
            <div id="buttons" style="position:absolute; right:75px; top:83px; z-Index:999;">
                <button dojoType="dijit.form.Button"   onClick="changeMap([streetMap]);">
                    Al Tareeq(EN)</button>
                <button dojoType="dijit.form.Button" onClick="changeMap([esriTopo]);">
                    Al Tareeq(AR)
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('roadmap')">
                    Google Street
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('satellite')">
                    Google Statellite
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('hybrid')">
                    Google Hybrid
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('terrain')">
                    Google Terrain
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([BingLayer]);BingLayer.setMapStyle('esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL');">
                    Bing Aerial
                </button>
                    Bing Aerial with labels
                </button>
                  <button dojoType="dijit.form.Button" onClick="changeMap([BingLayer]);">
                   Roads
                </button>
            </div>   </td>
            </tr>
            </table>
     </div>
        </form>
</body>
</html>
