Replace double click of last vertex with a Button click in Draw.POLYLINE
639
04-02-2013 07:56 AM
MiriEshel
Hi all,
I'm using esri.toolbars.Draw.POLYLINE and I want to replace the way I sketch the last vertex of the polyline: Instead of using Double click to finish sketching, I want to click on a button.
Is it possible and how?
Thanks a lot,
Miri
MarcusBush
How would you click the button without dragging your last polyline off of the drawing area?
BrettGreenfield__DNR_
Occasional Contributor II
I'm guessing the idea is to click a button and the polyline will be entered with the last vertex created as the final vertex.
Can you use the finishDrawing() method?  Create a button and have clicking it call a function that executes drawToolbar.finishDrawing();
MiriEshel
Hi Brett,
Thank you for your reply.
It works great!
Miri
MiriEshel
Maybe somebody knows how to undo the last point when sketching a PolyLine with the Draw toolbar?
I prefer using the Draw toolbar instead of the Editor object with FeatureLayer.
Thanks a lot,
Miri
