Repeated Calls to animateTo do not Honor Camera Elevation
2436
01-04-2016 10:24 AM
ThomasWeitzel
I have a simple UI that allows a user to click on an item in a grid (a location) and have the map pan to that location using the SceneView animateTo() method given a simple lat/long coordinate pair.  With Beta 1, this worked fine, the new camera location honored the z value that was set previously.  With Betas 2 and 3, repeated calls to animateTo() zoom the camera closer and closer to the ground.  Is this the expected behavior?
Here's a fiddle to demonstrate: https://jsfiddle.net/tweitzel/c5n3hv2g/
Thanks!
Tom
Tags (1)
ParitoshKowli1
A bug has been logged for this behaviour and following are details:
BUG-000093567: animateTo method of SceneView class show gray map if called multiple times.
ParitoshKowli1
