renderer.fromJSON
3013
6
05-21-2019 02:51 AM
deleted-user-wcpelUUf_XXx
I am trying to convert a layer back to its original drawing,after changing it.
the service include the layer in json form(i think) i tried both the fromJSON func and rewriting it manually but I think there is something wrong with the way i wrote it.
heres a codepen:
https://codepen.io/segev-salman/pen/MdEbwv
*is there a function to revertback to the original drawing or do i have to change the renderer with the full info inside?
RobertScheitlin__GISP
Then just clone the original renderer for latter use:
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Heat-map creator</title>
  <link rel="stylesheet" href="https://www.w3schools.com/w3css/4/w3.css">
  <style>
    #rendPanel {
      padding: 10px;
      background-color: rgba(255, 255, 255, 0.8);
    .esri-button {
      margin: 2px;
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <!-- <link rel="stylesheet" href="https://js.arcgis.com/4.11/esri/css/main.css"> -->
  <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.11/esri/themes/light/main.css"
  <script src="https://js.arcgis.com/4.11/"></script>
  <script>
    var origRend;
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/renderers/smartMapping/creators/heatmap"
    ], function (Map, MapView, FeatureLayer, heatmapRendererCreator) {
      var pov = new FeatureLayer({
        url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/ACS_Poverty_by_Age_Boundaries/FeatureServer/1",
        minScale: 40000000,
        maxScale: 4000
      var TF = new FeatureLayer({
        url: "https://services3.arcgis.com/1pxU2hJU9ZszJDcX/ArcGIS/rest/services/Young_Adult_Treatment_Facilities/FeatureServer/0",
      //apply HM to layer
      function apply(result) {
        origRend = TF.renderer.clone();
        TF.renderer = result.renderer;
      function remove() {
        console.log("removing")
        TF.renderer = origRend;
      var map = new Map({
        basemap: "gray",
        layers: [pov, TF]
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-102.370576, 40.172530],
        zoom: 5
      var heatmapParams = {
        layer: TF,
        basemap: map.basemap,
        field: "adlt",
        view: view
      document.getElementById("butt-1").addEventListener("click", function () {
        heatmapRendererCreator.createRenderer(heatmapParams).then(apply)
      document.getElementById("butt-2").addEventListener("click", function () {
        remove();
      view.ui.add("rendPanel", "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="rendPanel" class="esri-widget">
    <button id="butt-1" class="esri-button">
      create Heatmap
    </button>
    <button id="butt-2" class="esri-button">
      remove Heatmap
    </button>
  </div>
</body>
</html>
Segev,
   Here is your code working (with some UI changes):
<html>
<head>
  <style>
    #rendPanel {
      padding: 10px;
    .esri-button {
      margin: 2px;
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link
      rel="stylesheet"
  <script>
    require([
      "esri/Map",
        minScale: 40000000,
        maxScale: 4000
      //apply HM to layer
        console.log("applying")
      function remove() {
        /////instead of this
        TF.renderer = {
          type: "simple",
          symbol: {
            type: "simple-marker",
            style: "circle",
            color: [0, 197, 255, 255],
            outline: {
              color: [255, 255, 255, 255],
              width: 0.75
      var map = new Map({
        basemap: "gray",
        layers: [pov, TF]
        map: map,
        zoom: 5
        layer: TF,
        field: "adlt",
        view: view
        remove();
  </script>
</head>
<body>
      create Heatmap
    </button>
      remove Heatmap
    </button>
  </div>
</body>
</html>
Robert,
this is exactly what i wanted  to do, but I still want to know about the fromJSON or a different solution to handle multiple layers with different symbology.
lets say i have a select with three point layers so i could make a heatmap from each individually.
what would you do if you'd want the layers to go back to their original symbology.
i know you can just make a new FeatureLayer and add it but what if I gave the user the ability to query the layer and dont want to lose that info.
<html>
<head>
  <style>
    #rendPanel {
      padding: 10px;
    .esri-button {
      margin: 2px;
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link
      rel="stylesheet"
  <script>
    var origRend;
    require([
      "esri/Map",
        minScale: 40000000,
        maxScale: 4000
      //apply HM to layer
      function remove() {
      var map = new Map({
        basemap: "gray",
        layers: [pov, TF]
        map: map,
        zoom: 5
        layer: TF,
        field: "adlt",
        view: view
        remove();
  </script>
</head>
<body>
      create Heatmap
    </button>
      remove Heatmap
    </button>
  </div>
</body>
</html>
thank you so much that will work!
Robert,
You used the " class="esri-widget"" for the panel.
Does that mean Its possible to use the Expand function on it?
I am using this as an example:
https://developers.arcgis.com/javascript/latest/sample-code/widgets-expand/index.html
but Im not sure how to declare the panel or if its possible at all.
Sure just use:
      var bgExpand = new Expand({
        view: view,
        content: document.getElementById("rendPanel")
      view.ui.add(bgExpand, "top-right");
