Render setting for printing maps?
638
07-13-2023 11:24 AM
AndrewMurdoch1
Good Day
Is it possible to have one render setting for the map, but if you print it, you can change the render setting?
The problem I'm running into is that when you print a large map, it's just a cluttered mess, unless I thin out the geometries.  When I thin out the geometries, the cluttered issue goes away, BUT, the look of the map isn't usually ideal.  If you have a very large network it can be fine, but for smaller networks it just looks terrible.
To get around this problem, I was wondering if I can set a render setting that only be applied when you print.
