Remove the footer on the Map displayed
4893
01-06-2014 06:39 PM
sunithanaik
We are dynamically creating map by passing the lat and long parameter using the javascript api for ARCgis. However the default footer is displayed on map has to be removed. Can you please let me know how to remove the footer.
attached is the picture for the same
JeffPace
instead of destroying or hiding it, why not just turn it off?
map = new Map("map", { showAttribution: false });
AndyBurns
Depending on skill level you can code it out
https://developers.arcgis.com/en/javascript/jsapi/attribution-amd.html#destroy
or easy option
.esriAttribution {
display: none;
in the css or create custom css page and add
JeffPace
AndyBurns
Jeff's option is the best, go for that one!
Cheers Jeff, did not realize you could just turn it off like i use with the logo normally so thats changed some code for me!
sunithanaik
Thanks Jeff!
I did what you suggested and it solved the problem
JonathanUihlein
Sunitha, make sure you mark the thread as 'answered' (via the appropriate post) so that in the future, other people with a similar question can find the answer.
