remove previous graphic
13506
30
04-09-2012 10:37 AM
evanpicard
as many have read by now, I've got a data grid populated by a spatial query, and corresponding points in a map (red circles).
when you click on a record in the table, I would like a graphic added to the map to highlight (green circle) an already existing point(red circle). when you click a different record in the grid, i would like the first highlighter to disappear, and a new one appear.
right now, things go 2 ways, either the selected point never clears, and it adds more and more graphic points, or the last of the red query point graphics to be drawn disappears.
how do i specifically remove a graphic from selectedRepGraphic, not just the last graphic added, which is what happens now?
      function onRowClickHandler(evt){
        var clickedRep = grid.getItem(evt.rowIndex).rep_no;
        var selectedRep;
        var selectedRepSymbol = new esri.symbol.SimpleMarkerSymbol();
        selectedRepSymbol.style = esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE;
        selectedRepSymbol.setSize(10);
        selectedRepSymbol.setColor(new dojo.Color([0,255,0, 1]));
        dojo.forEach(map.graphics.graphics,function(graphic){
          if((graphic.attributes) && graphic.attributes.rep_no === clickedRep){
            selectedRep = graphic;
            var selectedRepGraphic = new esri.Graphic(selectedRep, selectedRepSymbol);
            selectedRepGraphic.setSymbol(selectedRepSymbol);
            var selInfoTemplate = new esri.InfoTemplate("Sales Rep: ${NAME}", ("${*}")); //"Rep # : ${rep_no}", "Address : ${ADDR1}");
            map.infoWindow.setTitle(selectedRepGraphic.getContent("${NAME}"));
            map.infoWindow.setContent(selectedRepGraphic.getContent("Sales Rep: ${NAME}", "Rep #: ${rep_no}", "Address : ${ADDR1}"));
            selectedRepGraphic.setInfoTemplate(selInfoTemplate);
            map.infoWindow.show(selectedRepGraphic.geometry);
            if (selectedRepGraphic != undefined){
              map.graphics.remove(map.graphics.graphics[map.graphics.graphics.length - 1]);
            map.graphics.add(selectedRepGraphic);
            return;
            return;
derekswingley1
Thats why I love these forums, lots of people working together to help each other.  It is a pleasure to be part of this community.
Indeed, we've got a good thing going here :).
evanpicard
Sorry to beat a dead horse here, but I'm trying to re-use this, and I cant get the previous point to disappear on an onClick event.
Here's my whole onclick function:
      function onClicker(evt){
        identifyTaskReps = new esri.tasks.IdentifyTask("http://server/ArcGIS/rest/services/IndivTerritoriesOnly/SalesReps_simple/MapServer/");
        identifyParamsReps = new esri.tasks.IdentifyParameters();
        identifyParamsReps.tolerance = 5;
        identifyParamsReps.returnGeometry = true;
        identifyParamsReps.layerIds = [0];
        identifyParamsReps.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
        identifyParamsReps.width  = map.width;
        identifyParamsReps.height = map.height;
        identifyParamsReps.geometry = evt.mapPoint;
        identifyParamsReps.mapExtent = map.extent;
        var deferred = identifyTaskReps.execute(identifyParamsReps);
        deferred.addCallback(function(response){
          if (response.length > 0) {
            return dojo.map(response, function(result){
              var feature = result.feature;
              var featureSymbol = new esri.symbol.SimpleMarkerSymbol();
              featureSymbol.style = esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE;
              featureSymbol.setSize(10);
              featureSymbol.setColor(new dojo.Color([0,255,0, 1]));
              feature.setSymbol(featureSymbol);
              feature.attributes.layerName = result.layerName;
              var infoTemplate = new esri.InfoTemplate();
              feature.setInfoTemplate(infoTemplate);
              var name = feature.attributes.NAME;
              var rep_no = feature.attributes.rep_no;
              var address = feature.attributes.ADDR1;
              var city = feature.attributes.CITY;
              var state = feature.attributes.ST_ABBR;
              var zipcode = feature.attributes.ZIP_CODE;
              var leader = feature.attributes.Ldr_type;
              var prez = feature.attributes.PCText;
              var content = "<b>Rep # : </b>" + rep_no + "<br><b>Address : </b>" + address + "<br><b>City : </b>" + city + "<br><b>State : </b>" + state + "<br><b>Zip : </b>" + zipcode + "<br><b> Leader : </b>" + leader + "<br><b>Presidents Club :</b>" + prez;
              var title = "<b>Name : </b>" + name;
              map.infoWindow.setTitle(title);
              map.infoWindow.setContent(content);
              map.graphics.add(feature);
              map.infoWindow.show(feature.geometry);
              this.highlightGraphic = new esri.Graphic(feature, featureSymbol);
              this.highlightGraphic.id = "highlight";
              dojo.forEach(this.map.graphics.graphics, function(g) {
                if (g && g.id === "highlight") {
                  //remove graphic with specific id
                  this.map.graphics.remove(g);
              }, this);
              this.map.graphics.add(this.highlightGraphic);
          return;
Please help!
Jeff?  Derek? Help!
evanpicard
help help? 🙂  please?
JeffPace
looking at your code (the last 3 blocks) you create the graphic, remove the graphic, then add the graphic.  I dont think that is the logic you want
is you onclick supposed to add a graphic or remove one?
evanpicard
all the points should have a graphic.
if you click on a point, a new "highlight point" should appear.  if you click on a second point, a new highlight point needs to appear, and the the first one needs to disappear.
thanks.
JeffPace
thanks.
That makes more sense.
First, remove the old graphic before you create the new one. (the forEach loop)
Second, remove all the "this"'s.  Looking at your code, you dont need them.
evanpicard
I'm seriously ready to slap my computer in its virtual face.
        dojo.forEach(map.graphics.graphics, function(g) {
          console.log(g.id)
          if ( g && g.id === "highlight" ) {
            map.graphics.remove(g); // <-- this doesn't remove anything.
        identifyTaskReps = new esri.tasks.IdentifyTask("http://172.26.197.91/ArcGIS/rest/services/IndivTerritoriesOnly/SalesReps_simple/MapServer/");
        identifyParamsReps.tolerance = 7;
//           console.log("response length ",  response.length)
//           response is an array of identify result objects
//           Let's return an array of features.
              var selFeature = result.feature;
              var selFeatureSymbol = new esri.symbol.SimpleMarkerSymbol();
              selFeatureSymbol.style = esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE;
              selFeatureSymbol.setSize(10);
              selFeatureSymbol.setColor(new dojo.Color([0,255,0, 1]));
              selFeature.setSymbol(selFeatureSymbol);
              selFeature.attributes.layerName = result.layerName;
              selFeature.setInfoTemplate(infoTemplate);
              var name = selFeature.attributes.NAME;
              var rep_no = selFeature.attributes.rep_no;
              var address = selFeature.attributes.ADDR1;
              var city = selFeature.attributes.CITY;
              var state = selFeature.attributes.ST_ABBR;
              var zipcode = selFeature.attributes.ZIP_CODE;
              var leader = selFeature.attributes.Ldr_type;
              var prez = selFeature.attributes.PCText;
              map.graphics.add(selFeature);
              map.infoWindow.show(selFeature.geometry);
              highlightGraphic = new esri.Graphic(selFeature, selFeatureSymbol);
              highlightGraphic.setSymbol;
              map.graphics.add(highlightGraphic);
map.graphics.remove(g);//<-- this doesn't remove anything.  If I change it to
map.graphics.clear();//            all graphics get cleared.
if I use console.log(g.id) I get logical results.  on the first click its nothing, on the second and any subsequent its "highlight"
please tell me I'm missing something stupid.
JeffPace
Okay i think i might have over generalized, and i am sorry for the frustration
          console.log(g.id)
the console see's g because you are passing it into the function, however it no longers knows what "map" is because the scope has changed
so
          console.log(g.id)
        }, this);
will keep the function in "this" scope which is aware of the "map" variable.
alternatively (same, just different syntax)
dojo.forEach(map.graphics.graphics, dojo.hitch(this, function(g) {
          console.log(g.id)
once you are in your "if", make sure you can alert map.  if not, you still have scope issues
evanpicard
Thank you for the help thus far.
Im going to be bald by the end of the day if I keep up all this hairpulling...
map.graphics.clear(); works, (and worked previously) but map.graphics.remove(g); does nothing.
as a test, within the IF i tried console.log(map.spatialReference), and it reported back to the console just fine.
        }, this);
              highlightGraphic.setSymbol(selFeatureSymbol);
derekswingley1
What do you see if you log the actual graphic being removed, as opposed to logging the map's spatial reference?
I would also recommend setting your "highlight" attribute on the graphic's attributes object, rather than on the graphic object itself.
Edit:  also, in your forEach, you don't need to specify "this" as the third argument since you're only referencing globals in your callback function.
