Remove Attachments Tag From PopupTemplate
2282
05-24-2017 10:13 AM
LloydBronn
I have a popuptemplate that displays a chart attachment for a feature. Is there a way to remove the text "Attachments:" from the popup and just show the attachment?
KellyHutchins
Esri Notable Contributor
With the popup attachments it is slightly different try this css.
      .attachmentsSection div:first-child{
        display:none;
RobertScheitlin__GISP
Lloyd,
   You will have to do this through direct DOM manipulation:
map.infoWindow.on("selection-change", function(){
  setTimeout(function(){
    var node = query(".attachmentsSection")[0];
    domStyle.set(node.children[0], "display", "none");
  }, 100);
KellyHutchins
You could also try using the following css to hide the 'Attachment's text.
.attachmentEditor > div > b {
    display: none;
LloydBronn
This didn't work. I'm not using an info template, just the popup template.
var popupTemplate = new PopupTemplate({
            showAttachments: true
KellyHutchins
        display:none;
LloydBronn
Thanks!
