registry is not defined
5808
8
02-29-2016 04:32 PM
LefterisKoumis
I am writing a code too fill combo box values to a form but I encounter the error that the registry is not defined even though it has been defined on line 40... Suggestions? Thank you.
require([ "dojo/ready",
        "dojo/on",
        "dojo/_base/connect",
        "dojo/dom",
        "dijit/registry",
        "dojo/dom-construct",
        "dojo/parser",
        "esri/arcgis/utils",
        "esri/domUtils",
  "esri/tasks/query", 'dijit/_WidgetsInTemplateMixin',
'dojox/xml/parser', 'dojox/data/XmlStore',
'esri/tasks/QueryTask',"dijit/Menu",
    "dijit/MenuItem",'dijit/form/Select',
  "dojo/domReady!"], function(
  ready,
        on,
        connect,
        dom,
        registry,
        domConstruct,
        parser,
        arcgisUtils,
        domUtils,
  Query, _WidgetsInTemplateMixin, parser,
  xmlParser, XmlStore,
  QueryTask, Menu, MenuItem, Select
  parser.parse();
  fillcountyselect();
   function fillcountyselect(){
    var select1 = registry.byId("countyfield");
  select1.addOption( {label:"Select County", value: 0});
KenBuja
MVP Esteemed Contributor
You also have a problem with your require modules/function arguments agreement. You have an extra "parcer" here:
_WidgetsInTemplateMixin, parser,  xmlParser
RobertScheitlin__GISP
Lefteris,
  It looks like your combo fill function is outside your main function thus unreachable
MiriamBrockmann
Hello Lefteris,
Robert is right. Your function and the call for the registry.byId lies outside the above defined require.
If you set it up it like this :
     require(["dijit/registry"],function(registry){
          ....u.s.o.
you have access to "registry".
Regards
LefterisKoumis
Thank you Miriam.
I still get a message that the "Cannot read property 'addOption' of undefined". It seems that the registry is still not recognized.
This is from the html.
  <select style="margin-top:10px;margin-bottom:10px;" id="countyfield" data-dojo-attach-point="countyfield" data-dojo-type="dijit/form/Select" data-dojo-attach-event="onChange:_onCountyClick"></select>
KenBuja
LefterisKoumis
One of my select is populated by an xml file. So, using just  xmlparser will be sufficient for the whole form?
Lefteris,
   No Ken is talking about the fact that you have "parser" listed twice and xmlParser once.
on,connect,dom,registry,domConstruct,parser,arcgisUtils,domUtils,Query, _WidgetsInTemplateMixin, parser,xmlParser, XmlStore,QueryTask, Menu, MenuItem, Select
LefterisKoumis
I need to have my eyes checked. How much time did I wasted for this! #$@$
Thank you all!
AZendel
I ran across this post when I was also getting an undefined variable after using
var myVar = registry.ById("myDIV);
My problem was that I hadn't used parse.parse() at the very top of the code in the main "function", like in this example. Just thought I'd mention this in hope that it'll save someone some time!
