Referencing layers in ArcGIS Services Directory
909
05-16-2012 07:11 AM
NickErlacker
I know you can reference different layers by using the ID number in provided by the ArcGIS Services Directory. But, when a new service is added sometimes the number changes and as a result you web map references the wrong service.Is there a way to reference the correct service without using the ID provided by the ArcGIS Services Directory? May be the service name and if so is there any examples in javascript?
JMcNeil
Nick,
This post might help you out...sounds like a solution is there somewhere.  If it does help you, you should mark the solution in the post and in your post so others can find it easier.
http://forums.arcgis.com/threads/20898-using-layer-name-instead-of-layer-id?highlight=layer
Jay
