ReferenceError: Portal is not defined
3805
07-22-2020 10:07 AM
CarolineGlazer2
Hi everyone,
I'm trying to set up a web app using Esri Leaflet, but using ArcGIS API for JavaScript to handle authentication. I've managed to get authentication working (I think), but I'm getting an error when I try to define a new portal to check the user is logged in "ReferenceError: Portal is not defined." I'm pretty new to javascript and I assume I'm using the require / function syntax incorrectly somehow - I copied bits and pieces from here: Access services with OAuth 2.0 | ArcGIS for Developers
Any insight would be very much appreciated - thank you! Code below:
<!DOCTYPE HTML>
<html>
<head>
 <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
 <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
 <title>blahblahblah</title>
 <!-- Load Leaflet from CDN -->
 <link rel="stylesheet" href="https://unpkg.com/[email protected]/dist/leaflet.css" integrity="sha512-xwE/Az9zrjBIphAcBb3F6JVqxf46+CDLwfLMHloNu6KEQCAWi6HcDUbeOfBIptF7tcCzusKFjFw2yuvEpDL9wQ==" crossorigin="" />
 <script src="https://unpkg.com/[email protected]/dist/leaflet.js" integrity="sha512-gZwIG9x3wUXg2hdXF6+rVkLF/0Vi9U8D2Ntg4Ga5I5BZpVkVxlJWbSQtXPSiUTtC0TjtGOmxa1AJPuV0CPthew==" crossorigin=""></script>
<!-- Load Esri Leaflet from CDN -->
 <script src="https://unpkg.com/[email protected]/dist/esri-leaflet.js" integrity="sha512-xY2smLIHKirD03vHKDJ2u4pqeHA7OQZZ27EjtqmuhDguxiUvdsOuXMwkg16PQrm9cgTmXtoxA6kwr8KBy3cdcw==" crossorigin=""></script>
 <script src="https://js.arcgis.com/4.15/"></script>
 <link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
<script>
 require([
 "esri/portal/Portal",
 "esri/identity/OAuthInfo",
 "esri/identity/IdentityManager"
 ], function(
 Portal, OAuthInfo, identityManager) {
 // ArcGIS Online or your portal address
 var portalUrl = "https://www.arcgis.com/sharing";
// subsitute your own client ID to identify who spawned the login and check for a matching redirect URI
 var info = new OAuthInfo({
 appId: "blahblahblah", //*** Your Client ID value goes here ***//
 popup: false // inline redirects don't require any additional app configuration
identityManager.registerOAuthInfos([info]);
// send users to arcgis.com to login
 document.getElementById("sign-in").onclick = function() {
 identityManager.getCredential(portalUrl);
// log out and reload
 document.getElementById("sign-out").onclick = function() {
 identityManager.destroyCredentials();
 window.location.reload();
identityManager.checkSignInStatus(portalUrl).then(function() {
 document.getElementById('anonymousPanel').style.display = 'none';
 document.getElementById('personalizedPanel').style.display = 'block';
 displayMap();
function displayMap() {
 var portal = new Portal();
// Once the portal has loaded, the user is signed in
 portal.load().then(function() {
 console.log('logged in');
 var map = L.map('map').setView([-122.479, 37.837], 10);
L.esri.basemapLayer('Gray').addTo(map);
L.esri.featureLayer({
 url: 'https://sampleserver6.arcgisonline.com/arcgis/rest/services/Earthquakes_Since1970/MapServer/0'
 }).addTo(map);
</script>
 <style>
 html,
 body,
 #viewDiv {
 font-family: Avenir Next W00;
 font-size: 14px;
 width: 100%;
 height: 100%;
 margin: 0px;
 padding: 0px;
.action {
 color: blue;
 cursor: pointer;
 text-decoration: underline;
#map {
 position: absolute;
 top: 0;
 bottom: 0;
 right: 0;
 left: 0;
</style>
</head>
<body>
 <div id="anonymousPanel" style="display: block; padding: 5px; text-align: center;">
 <span id="sign-in" class="action">Sign In</span> to access SCMSN Stewardship Layers.
 </div>
<div id="personalizedPanel" style="display: none; padding: 5px; text-align: center;">
 Welcome <span id="userId" style="font-weight: bold;"></span>  -
 <span id="sign-out" class="action">Sign Out</span>
 </div>
 <!-- for the map -->
 <div id="viewDiv" style="display: none;"></div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
KenBuja
MVP Esteemed Contributor
You closed off the require function at line 53, which means the displayMap function fell outside of it. You have to move that closure to line 70
<!DOCTYPE HTML>
<html>
<head>
  <script>
    require([
    ], function (
      document.getElementById("sign-in").onclick = function () {
      document.getElementById("sign-out").onclick = function () {
      identityManager.checkSignInStatus(portalUrl).then(function () {
        displayMap();
//   }); this is the original closure
        portal.load().then(function () {
          }).addTo(map);
    }); //this is the new closure
  </script>
  <style>
    html,
    body,
    #viewDiv {
      font-size: 14px;
      width: 100%;
      height: 100%;
      margin: 0px;
      padding: 0px;
    .action {
      color: blue;
      cursor: pointer;
    #map {
      position: absolute;
      top: 0;
      bottom: 0;
      right: 0;
      left: 0;
  </style>
</head>
<body>
  </div>
  </div>
</body>
</html>
KenBuja
<!DOCTYPE HTML>
<html>
<head>
  <script>
    require([
    ], function (
        displayMap();
          }).addTo(map);
  </script>
  <style>
    html,
    body,
    #viewDiv {
      font-size: 14px;
      width: 100%;
      height: 100%;
      margin: 0px;
      padding: 0px;
    .action {
      color: blue;
      cursor: pointer;
    #map {
      position: absolute;
      top: 0;
      bottom: 0;
      right: 0;
      left: 0;
  </style>
</head>
<body>
  </div>
  </div>
</body>
</html>
CarolineGlazer2
Thank you!
