Reference the Featureset for a geoprocessing task
2158
10-03-2013 07:38 AM
ionarawilson1
I am calling a geoprocessing service in a web app. The geoprocessing service has one parameter. But I am not sure how to find the parameter in the javascript code to send it to the geoprocessing since I am using an editor widget to first create the polygon and then run the geoprocessing service. Can you guys take a look at my code and tell me how I reference a feature set from the editor widget results? Thank you!
   var stewardship = new FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/MyMapService2/FeatureServer/2",{           mode: FeatureLayer.MODE_ONDEMAND,            outFields: ['*']         });          map.addLayers([ActivityArea,ActivityPoint,stewardship]);                          function initEditor(evt) {             var templateLayers = arrayUtils.map(evt.layers, function(result){             return result.layer;               });           var templatePicker = new TemplatePicker({             featureLayers: templateLayers,             grouping: true,             rows: "auto",             columns: 3           }, "templateDiv");           templatePicker.startup();            var layers = arrayUtils.map(evt.layers, function(result) {             return { featureLayer: result.layer };           });           var settings = {             map: map,             templatePicker: templatePicker,             layerInfos: layers,             toolbarVisible: true,             createOptions: {               polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],               polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,                 Editor.CREATE_TOOL_CIRCLE,                 Editor.CREATE_TOOL_TRIANGLE,                 Editor.CREATE_TOOL_RECTANGLE               ]             },             toolbarOptions: {               reshapeVisible: true             }                   };            var params = {settings: settings};               var myEditor = new Editor(params,'editorDiv');           //define snapping options           var symbol = new SimpleMarkerSymbol(             SimpleMarkerSymbol.STYLE_CROSS,              15,              new SimpleLineSymbol(               SimpleLineSymbol.STYLE_SOLID,                new Color([255, 0, 0, 0.5]),                5             ),              null           );           map.enableSnapping({             snapPointSymbol: symbol,             tolerance: 20,             snapKey: keys.ALT           });                myEditor.startup();         }            gp = new esri.tasks.Geoprocessor("http://tfsgis-iisd01:6080/arcgis/rest/directories/arcgisoutput/CalcFeaturesStewardshipNoParam4_GPServer/CalcFeaturesStewardshipNoParam4")   gp.setOutSpatialReference({wkid:102100});           on(dom.byId("button"),"click", function() {           alert("TEST")      //    gp.submitJob(params, completeCallback , statusCallback,function(error){ //          alert(error);          });
The Python
import os, sys, arcpy arcpy.env.workspace = "Database Connections\\sars.sde\\"  value = arcpy.GetParameterAsText(0)   Input_Polygons = "Stewardship"   Input_Polygons_Layer = "SamplePoints_Layer"  arcpy.MakeFeatureLayer_management(Input_Polygons, Input_Polygons_Layer)  with arcpy.da.UpdateCursor(Input_Points_Layer, ("City")) as rows:                  for row in rows:             row[0] = value                         rows.updateRow(row)
ionarawilson1
This worked. Stewardship is the id of the feature layer
var featureSet = new esri.tasks.FeatureSet();         var layer=map.getLayer("stewardship")        featureSet.features = layer.graphics;      featureSet.fields=layer.fields;          featureSet.spatialReference = map.spatialReference;             spatial = featureSet.spatialReference      featureSet.geometryType=layer.geometryType;     geometry = featureSet.geometryType     var count = featureSet.features.length;    alert(count)    alert(geometry)    alert(spatial)         var params = {"Stewardship":featureSet}     gp.submitJob(params, completeCallback , statusCallback)              });      function completeCallback(jobInfo){         console.log("testing")}
ionarawilson1
Hi Guys,
I changed the script to create a featureset from the featurelayer (function getFeatureSetFromFLayer), but it is not working. I am not even getting an error, which means the parameter (featureSet) is not even being read. Any ideas why? Thank you for any help!
          outFields: ['*']
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          var settings = {
            map: map,
            layerInfos: layers,
            createOptions: {
            toolbarOptions: {
            15,
            null
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
 function getFeatureSetFromFLayer(){
  //create featuresets
  //get featurelayer from map's featurelayer (ex:myFeatureLayer)
  //get features from featurelayer
  featureSet.fields = layer.fields;
  //assign map's spatial reference
  // Assumption: map variable is esri.Map instance in the application
  //assign geometryType
  featureSet.geometryType = layer.geometryType;
  return featureSet;
  gp = new esri.tasks.Geoprocessor("http://tfsgis-iisd01:6080/arcgis/rest/services/CalcFeaturesStewardshipOneParameter3/GPServer/CalcFeaturesStewardshipOneParameter")
  gp.outSpatialReference = map.spatialReference
          var params = {Stewardship: featureSet}
      function statusCallback(jobInfo) {
        var status = jobInfo.jobStatus;
        if(status === "esriJobFailed"){
          alert(status);
        else if (status === "esriJobSucceeded"){
          alert(status);
And the Python
# Import arcpy module
# Script arguments
Selecting_Features = arcpy.GetParameterAsText(0)
#Final_Output = value
# Process: Make Feature Layer
#arcpy.MakeFeatureLayer_management(Input_Polygons, Input_Polygons_Layer)
# Process: Select Layer By Location
with arcpy.da.UpdateCursor(Input_Polygons, ("DateStart", "FFY")) as rows:
    for row in rows:
       Datestarstr1 = row[0]
       Datestarstr2 = str(Datestarstr1)
       yearonly = Datestarstr2[0:4]
       row[1] = yearonly
       rows.updateRow(row)
ionarawilson1
I think I am pretty close, I thought I could grab the graphics from the map to act as features to be the input parameter, but no luck so far.
  var features= [];
  var params = {Stewardship:featureSet}
ionarawilson1
