Reference the ArcGIS API for JavaScript using StealJS
1490
05-03-2013 07:41 AM
SongHu
Has anyone tried to reference the ArcGIS API for JavaScript using StealJS instead of adding
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css">
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script>
to the <head> tag?
I tried to use:
steal("http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/")
    .css("http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri")
but StealJs thinks i am looking for "http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/.js" and reports not found(404).
JeffJacobson
to the <head> tag?
I tried to use:
I don't know what StealJS is, but if it requires a path to a JS file you can probably use one of the following URLs
JeffJacobson
to the <head> tag?
I tried to use:
MattLane
This happens in jsfiddle too, you can try appending a ? after the trailing slash, or remove the trailing slash altogether.
SongHu
