Receiving undefined is not a function when I try to implement the Measurement example
3395
11-19-2014 02:01 PM
ChrisSergent
I tried create the measurement tool based on our web services and I receive the following error message: Uncaught TypeError: undefined is not a function for line 127
What is causing that? Here is my code:
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
            #titlePane
                width:240px;
                position:absolute;
                right:20px;
                top:10px;
                z-index:999;
            .soria  .dijitTitlePaneTitle {
                background: #fff;
                font-weight:600;
                border: none;
                border-bottom:solid 1px #29201A;
                border-top:solid 1px #29201A;
            .soria .dijitTitlePaneTitleHover
                background:#eee;
            .soria .dijitTitlePaneTitleActive
                background:#808775;
            .soria .dijitTitlePaneContentOuter
                border-right: none;
                border-bottom: none;
                border-left: none;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            require(["esri/map", "esri/config",
                     "dojo/parser",
                     "esri/renderers/SimpleRenderer",
                     "esri/Color",
                     "esri/dijit/Measurement",
                     "esri/dijit/Scalebar",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/SnappingManager",
                     "esri/sniff",
                     "esri/symbols/SimpleFillSymbol",
                     "esri/symbols/SimpleLineSymbol",
                     "esri/tasks/GeometryService",
                     "dijit/layout/BorderContainer",
                     "dijit/layout/ContentPane",
                     "dijit/form/CheckBox",
                     "dijit/TitlePane",
                     "dojo/dom",
                     "dojo/keys",
                     "dojo/on",
                     "dojo/domReady!"], function (Map, esriConfig, parser, SimpleRenderer, Color, Measurement, Scalebar, Extent,
                                                 ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, FeatureLayer, SnappingManager,
                                                 has, SimpleFillSymbol, SimpleLineSymbol, GeometryService, dom, keys, on
                         parser.parse();
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // start measurement tool - the current layer we are measuring is the operational layer
                         var sfs = new SimpleFillSymbol(
                         "solid",
                         new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
                         null
                         operationalLayer.setRenderer(new SimpleRenderer(sfs));
                         //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
                         var snapManager = map.enableSnapping({
                             snapKey: has("mac") ? keys.META : keys.CTRL
                         var layerInfos = [{
                             layer: operationalLayer
                         snapManager.setLayerInfos(layerInfos);
                         var measurement = new Measurement({
                             map: map
                         }, dom.byId("measurementDiv"));
                         measurement.startup();
                         // end measurement tool
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv"></div>
        <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closeable:'false',open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
        </div>
    </body>
</html>
OwenEarley
There is a syntax error on the line that is throwing the error. However, you don't need to wrap the layer drawing options code in a function - my example was just taken from the ESRI documentation.
    // error follows this line
    // function (LayerDrawingOptions, SimpleRenderer) {  <-- Remove this line
    var layerDrawingOptions = [];
    var layerDrawingOption = new LayerDrawingOptions();
         "solid",
         null
    // } <-- Remove function closure
    layerDrawingOption.renderer = new SimpleRenderer(sfs);
    // The dynamicData object does not exist in your code - it is from the ESRI sample:
    //dynamicData.setLayerDrawingOptions(layerDrawingOptions);
    operationalLayer.setLayerDrawingOptions(layerDrawingOptions);
There still appear to be some issues with the measure functionality.
OwenEarley
Your operationalLayer is an ArcGISDynamicMapServiceLayer and this object does not have a setRenderer() method. You should use the setLayerDrawingOptions() method instead:
require([
  "esri/layers/LayerDrawingOptions", "esri/renderers/SimpleRenderer", ...
], function(LayerDrawingOptions, SimpleRenderer, ... ) {
                    "solid",
                    null
    // change 1 to the layer index that you want to modify:
    layerDrawingOptions[1] = layerDrawingOption;
ChrisSergent
I updated my code as follows, but I get the error Uncaught SyntaxError: Unexpected token (  at the line where I say error occurs here:
<!DOCTYPE html>
<html>
    <head>
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
            #titlePane
                width:240px;
                position:absolute;
                right:20px;
                top:10px;
                z-index:999;
                background: #fff;
                font-weight:600;
                border: none;
                background:#eee;
                background:#808775;
                border-right: none;
                border-left: none;
        </style>
        <script>
            var map;
                     "dojo/parser",
                     "esri/Color",
                     "esri/sniff",
                     "dijit/TitlePane",
                     "dojo/dom",
                     "dojo/keys",
                     "dojo/on",
                                                 ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, LayerDrawingOptions, SnappingManager,
                         parser.parse();
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                                 "wkid": 3435
                         // add imagery
                                            "solid",
                                            null
                         var layerInfos = [{
                             map: map
        </script>
    </head>
        </div>
    </body>
</html>
OwenEarley
         "solid",
         null
ChrisSergent
Your updated code worked. I just needed to move my dojo require statements above the dijits to line up with the declarations in the function.
