Receiving an error on spatial reference for geolocation
6359
16
11-18-2014 07:35 AM
ChrisSergent
I am receiving this error when I attempt to use geolocation:
Map: Geometry (wkid: 4326) cannot be converted to spatial reference of the map (wkid: 3435)
What do I need to add in my following code to make this work?
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
            @-webkit-keyframes
            pulse
                0%
                 opacity:1.0;
                45%
                 opacity:.20;
                100%
                 opacity:1.0;
            @-moz-keyframes
              pulse
              0%
                 opacity:1.0;
               45%
                 opacity:.20;
                100%
                 opacity:1.0;
              #map_graphics_layer {
                -webkit-animation-duration: 3s;
                -webkit-animation-iteration-count: infinite;
                -webkit-animation-name: pulse;
                -moz-animation-duration: 3s;
                -moz-animation-iteration-count: infinite;
                -moz-animation-name: pulse;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            var graphic;
            var currLocation;
            var watchId;
            require(["esri/map", "esri/config",
                     "esri/Color",
                     "esri/geometry/Extent",
                     "esri/geometry/Point",
                     "esri/graphic",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/symbols/SimpleLineSymbol",
                     "esri/symbols/SimpleMarkerSymbol",
                     "esri/tasks/GeometryService",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/domReady!"], function (Map, esriConfig, Color, Extent, Point, Graphic,
                                                  ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  SimpleLineSymbol, SimpleMarkerSymbol, GeometryService, dom, on, parser
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // geolocation functionality starts here
                         map.on("load", initFunc);
                         function orientationChanged() {
                             if (map) {
                                 map.reposition();
                                 map.resize();
                         function initFunc(map) {
                             if (navigator.geolocation) {
                                 navigator.geolocation.getCurrentPosition(zoomToLocation, locationError);
                                 watchId = navigator.geolocation.watchPosition(showLocation, locationError);
                             } else {
                                 alert("Browser doesn't support Geolocation. Visit http://caniuse.com to see browser support for the Geolocation API.");
                         function locationError(error) {
                             //error occurred so stop watchPosition
                                 navigator.geolocation.clearWatch(watchId);
                             switch (error.code) {
                                 case error.PERMISSION_DENIED:
                                     alert("Location not provided");
                                     break;
                                 case error.POSITION_UNAVAILABLE:
                                     alert("Current location not available");
                                     break;
                                 case error.TIMEOUT:
                                     alert("Timeout");
                                     break;
                                 default:
                                     alert("unknown error");
                                     break;
                         function zoomToLocation(location) {
                             var pt = new Point(location.coords.longitude, location.coords.latitude);
                             addGraphic(pt);
                             map.centerAndZoom(pt, 12);
                         function showLocation(location) {
                             //zoom to the users location and add a graphic
                             if (!graphic) {
                                 addGraphic(pt);
                             } else { // move the graphic if it already exists
                                 graphic.setGeometry(pt);
                             map.centerAt(pt);
                         function addGraphic(pt) {
                             var symbol = new SimpleMarkerSymbol(
                                    SimpleMarkerSymbol.STYLE_CIRCLE,
                                    12,
                                    new SimpleLineSymbol(
                                      SimpleLineSymbol.STYLE_SOLID,
                                      new Color([210, 105, 30, 0.5]),
                                      8
                                    new Color([210, 105, 30, 0.9])
                             graphic = new Graphic(pt, symbol);
                             map.graphics.add(graphic);
        </script>
    </head>
    <body onorientationchange="orientationChanged();" class="soria">
        <div id="mapDiv"></div>
    </body>
</html>
Tags (1)
RobertScheitlin__GISP
Chris,
  Your issue is the the project method is an async method and you have to wait for its response before the pnt is actually projected. Your next issue is that the outSR is not expecting a string, but an actual SpatialReference object. The final issue is you are assigning a transformation (as you should be) but you are using the wkid of 4326, which is not a transformation wkid.
Here is your code updated:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    @-webkit-keyframes
    pulse {
      0% {
        opacity: 1.0;
      45% {
        opacity: .20;
        100% {
          opacity: 1.0;
      @-moz-keyframes
      pulse {
        0% {
          opacity: 1.0;
        45% {
          opacity: .20;
        100% {
          opacity: 1.0;
  </style>
  <script>
    var map;
    var graphic;
    var currLocation;
    var watchId;
    var pt;
                     "esri/Color",
                     "esri/graphic",
                     "esri/tasks/ProjectParameters",
                     "esri/SpatialReference",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
      SimpleLineSymbol, SimpleMarkerSymbol, GeometryService, ProjectParameters, SpatialReference, dom, on, parser
        "xmin": 777229.03,
        "ymin": 1133467.92,
        "xmax": 848340.14,
        "ymax": 1185634.58,
          "wkid": 3435
      // add imagery
        "opacity": 0.5
        if (map) {
          map.reposition();
          map.resize();
        } else {
          break;
          break;
        case error.TIMEOUT:
          alert("Timeout");
          break;
        default:
          break;
        var geopt = new Point(location.coords.longitude, location.coords.latitude);
        var params = new ProjectParameters();
        params.geometries = [geopt];
        params.outSR = new SpatialReference(3435);
        params.transformation = 108190;
        params.transformForward = true;
        esriConfig.defaults.geometryService.project(params, function(projectedPoints){
          pt = projectedPoints[0];
          addGraphic(pt);
          if (!graphic) {
            addGraphic(pt);
          map.centerAt(pt);
          12,
            8
  </script>
</head>
</body>
</html>
PaulCrickard1
Maybe create a Spatial reference
var sr = new SpatialReference(4326);
and then when you create the map add it
                             extent: initialExtent,
                              spatialReference: sr
then the location will be the same as the SR of the map - because the map is now 4326
ChrisSergent
It looks like this would conflict with my extent:initialExtent which uses a different spatial reference. I tried it though and I receive a blank page.
PaulCrickard1
Yes, your initial extent will now need to be in latlong (4326 )
ChrisSergent
Our data uses a wkid of 3435. For accuracy, we need to use the 3435 wkid. The init.js file has a wkid of 4326, but I'm not sure how to work with the two to convert what I need.
ReneRubalcava
Esri Frequent Contributor
That is werd because the docs say that if you construct the map with an Extend and spatial reference,everything should work as long as all other layers match.
map-amd | API Reference | ArcGIS API for JavaScript
If provided, the extent and projection of the map is set to the properties of Extent. Once the projection is set, all layers must be able to be drawn in the defined projection. The tiling scheme of an ArcGISTiledMapServiceLayer must match the projection of the map. The projection of the extent is honored when used in the map constructor.
What you may want to try Chris is don't initialize the extent in the constructor, instead wait for the map to load the tiled layer and then set the extent. It will inherit the spatial reference and default extents of the tiled layer and should accept the new extent.
I had a similar issue in a local NAD spatial reference and in my case I think I just dropped the initial extent altogether, I could never get it to honor it and now I just have the map move to the previously loaded extent after it has been created.
ChrisSergent
How should I modify the code to do that?
ReneRubalcava
You could try something like this.
     "xmin": 777229.03,
     "ymin": 1133467.92,
     "xmax": 848340.14,
     "ymax": 1185634.58,
         "wkid": 3435
 // create map and set slider style to small **LEAVE OUT EXTENT HERE**
map.on("load", initFunc); // **SET LOAD LISTENER BEFORE ADDING TILED LAYER**
// add imagery
  map.setExtent(initialExtent); // **SET EXTENT HERE**
  } else {
MattDriscoll
You need to project the graphic into your maps spatial reference. That should fix everything. geometryservice-amd | API Reference | ArcGIS API for JavaScript
You could just use the LocateButton to handle all of this code for you.
locatebutton-amd | API Reference | ArcGIS API for JavaScript
ChrisSergent
I was thinking something like this:
require(["esri/geometry/Point"], function(Point) { new Point(x,y,3435});
but since it's geolocation I don't know what the x and y will be. And is this code even correct that I wrote?
