Receiving an error on spatial reference for geolocation
6392
16
11-18-2014 07:35 AM
ChrisSergent
I am receiving this error when I attempt to use geolocation:
Map: Geometry (wkid: 4326) cannot be converted to spatial reference of the map (wkid: 3435)
What do I need to add in my following code to make this work?
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
            @-webkit-keyframes
            pulse
                0%
                 opacity:1.0;
                45%
                 opacity:.20;
                100%
                 opacity:1.0;
            @-moz-keyframes
              pulse
              0%
                 opacity:1.0;
               45%
                 opacity:.20;
                100%
                 opacity:1.0;
              #map_graphics_layer {
                -webkit-animation-duration: 3s;
                -webkit-animation-iteration-count: infinite;
                -webkit-animation-name: pulse;
                -moz-animation-duration: 3s;
                -moz-animation-iteration-count: infinite;
                -moz-animation-name: pulse;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            var graphic;
            var currLocation;
            var watchId;
            require(["esri/map", "esri/config",
                     "esri/Color",
                     "esri/geometry/Extent",
                     "esri/geometry/Point",
                     "esri/graphic",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/symbols/SimpleLineSymbol",
                     "esri/symbols/SimpleMarkerSymbol",
                     "esri/tasks/GeometryService",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/domReady!"], function (Map, esriConfig, Color, Extent, Point, Graphic,
                                                  ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  SimpleLineSymbol, SimpleMarkerSymbol, GeometryService, dom, on, parser
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // geolocation functionality starts here
                         map.on("load", initFunc);
                         function orientationChanged() {
                             if (map) {
                                 map.reposition();
                                 map.resize();
                         function initFunc(map) {
                             if (navigator.geolocation) {
                                 navigator.geolocation.getCurrentPosition(zoomToLocation, locationError);
                                 watchId = navigator.geolocation.watchPosition(showLocation, locationError);
                             } else {
                                 alert("Browser doesn't support Geolocation. Visit http://caniuse.com to see browser support for the Geolocation API.");
                         function locationError(error) {
                             //error occurred so stop watchPosition
                                 navigator.geolocation.clearWatch(watchId);
                             switch (error.code) {
                                 case error.PERMISSION_DENIED:
                                     alert("Location not provided");
                                     break;
                                 case error.POSITION_UNAVAILABLE:
                                     alert("Current location not available");
                                     break;
                                 case error.TIMEOUT:
                                     alert("Timeout");
                                     break;
                                 default:
                                     alert("unknown error");
                                     break;
                         function zoomToLocation(location) {
                             var pt = new Point(location.coords.longitude, location.coords.latitude);
                             addGraphic(pt);
                             map.centerAndZoom(pt, 12);
                         function showLocation(location) {
                             //zoom to the users location and add a graphic
                             if (!graphic) {
                                 addGraphic(pt);
                             } else { // move the graphic if it already exists
                                 graphic.setGeometry(pt);
                             map.centerAt(pt);
                         function addGraphic(pt) {
                             var symbol = new SimpleMarkerSymbol(
                                    SimpleMarkerSymbol.STYLE_CIRCLE,
                                    12,
                                    new SimpleLineSymbol(
                                      SimpleLineSymbol.STYLE_SOLID,
                                      new Color([210, 105, 30, 0.5]),
                                      8
                                    new Color([210, 105, 30, 0.9])
                             graphic = new Graphic(pt, symbol);
                             map.graphics.add(graphic);
        </script>
    </head>
    <body onorientationchange="orientationChanged();" class="soria">
        <div id="mapDiv"></div>
    </body>
</html>
Tags (1)
MattDriscoll
That won't work. the location will always be returned in 4326 coordinates.
So in showLocation() you just need to convert that point into your map's spatial reference with esri.config.geometryService.project();
Project a point | ArcGIS API for JavaScript
geometryservice-amd | API Reference | ArcGIS API for JavaScript
                             var pt = new Point(location.coords.longitude, location.coords.latitude); // this is 4326
// project this point here
// then after it's projected, add it to map
                             if (!graphic) {
                                 addGraphic(pt);
                             map.centerAt(pt);
ChrisSergent
I added the information in the require statement and the declarations and changed my code as follows (what am I doing wrong?):
// modified code starts here
                             var params = new ProjectParameters();
                             params.geometries = [pt];
                             params.outSR = "3435";
                             params.transformation = "4326";
                             esriConfig.defaults.geometryService.project(params);
                             addGraphic(pt);
                             if (!graphic) {
                                 addGraphic(pt);
                             map.centerAt(pt);
                         // modified code ends here
RobertScheitlin__GISP
Chris,
  Your issue is the the project method is an async method and you have to wait for its response before the pnt is actually projected. Your next issue is that the outSR is not expecting a string, but an actual SpatialReference object. The final issue is you are assigning a transformation (as you should be) but you are using the wkid of 4326, which is not a transformation wkid.
Here is your code updated:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    @-webkit-keyframes
    pulse {
      0% {
        opacity: 1.0;
      45% {
        opacity: .20;
        100% {
          opacity: 1.0;
      @-moz-keyframes
      pulse {
        0% {
          opacity: 1.0;
        45% {
          opacity: .20;
        100% {
          opacity: 1.0;
  </style>
  <script>
    var map;
    var graphic;
    var currLocation;
    var watchId;
    var pt;
                     "esri/Color",
                     "esri/graphic",
                     "esri/tasks/ProjectParameters",
                     "esri/SpatialReference",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
      SimpleLineSymbol, SimpleMarkerSymbol, GeometryService, ProjectParameters, SpatialReference, dom, on, parser
        "xmin": 777229.03,
        "ymin": 1133467.92,
        "xmax": 848340.14,
        "ymax": 1185634.58,
          "wkid": 3435
      // add imagery
        "opacity": 0.5
        if (map) {
          map.reposition();
          map.resize();
        } else {
          break;
          break;
        case error.TIMEOUT:
          alert("Timeout");
          break;
        default:
          break;
        var geopt = new Point(location.coords.longitude, location.coords.latitude);
        params.geometries = [geopt];
        params.outSR = new SpatialReference(3435);
        params.transformation = 108190;
        params.transformForward = true;
        esriConfig.defaults.geometryService.project(params, function(projectedPoints){
          pt = projectedPoints[0];
          addGraphic(pt);
          if (!graphic) {
            addGraphic(pt);
          map.centerAt(pt);
          12,
            8
  </script>
</head>
</body>
</html>
ChrisSergent
This works. Thanks. Where does the 108190 from?
Chris,
   Here is info about geo tranformations
If you click on the last link "GIS Projection Engine 10.1 Datum transformation methods and appropriate geographic areas" you will get a zip file that has a pdf listing all transformations.
ReneRubalcava
Esri Frequent Contributor
Haha, Matt's right. My head was totally somewhere else her, sorry Chris.
ChrisSergent
Thanks, I documented that in my code so I would have a reference.
