React Wrapper
2177
6
06-13-2023 07:44 AM
AddisonShaw
Are there any plans for an officially supported React Wrapper of the ArcGIS JS SDK?
AndyGup
Hi @AddisonShaw we don't have any plans for framework-specific wrappers, such as React.
Brian_Wilson
Honored Contributor
If you have one you like that's not from Esri would you post a link here? I will do likewise. Thanks, Brian
AddisonShaw
I've actually been wrapping it in an internal library. I could probably share a few component examples, or at least the general pattern I've come up with for things like layers and widgets.
Brian_Wilson
Honored Contributor
If you push into a github repo I would try to contribute. I am not using the SDK right now because I am on a non-spatial project but plan on returning to it in July.
AddisonShaw
If we reach a point where we can open source the library, I will. Otherwise, reach out to me if you need help in the future and I can either post examples here or to you directly.
AndyGup
Brian_Wilson
Honored Contributor
Thanks for clarifying that.
