I'm running into serveral problems adding Feature Layer to a Web App using the LocalLayer Widget under Web AppBuilder 2.5 or 2.6 Developer Edition. I don't think that LocalLayer Widget is the problem as the errors occur prior to the call of this widget.
The task:
In a later project phase I want to add dynamically feature layers to a Web app following certain business rules. A former question in GeoNet was, how to do this. The answer was: don't do this on your own, use LocalLayer Widget (LLW) to bring additional Feature Layers to your app!
So I configured LLW for using both layers below, and configured jsons, so that LLW occurs in my local app. Good.
The base Web Map in AGOL consists of a OpenStreetMap base map and one Feature Layer
Now I want to add these two additional AGOL layers to my Web App via LLW:
https://services.arcgis.com/pvGPZRwU4kBQ1Sx6/arcgis/rest/services/beispielflaechen/FeatureServer/0
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer
The problem:
No matter, if I use proxy or not, loading layers via LLW doesn't work :-(. And as stated above: even loading my plain Web App prior to LLW is causing error messages.
What Am I doing wrong?
Base:
- WAB 2.6 Developer Edition (starting with 2.5, same symptoms)
- Visual Studio Code
- Node.js
- Web map with OpenStreetMap and 1 Feature Layer from AGOL "Bushaltestellen_Muenchen_OSM"
I registered the app for using data source http://localhost:3345/webappbuilder, redirect URIs are http://localhost:3345, https://localhost:3346.
- Optional: using PHP-Proxy (v5.6) running via grunt-php task. Works fine according to logs
Steps to reproduce the problems:
Step 1 - invoking Web App (http://localhost:3345/webappbuilder/apps/14/) --> NOK: error message(s):
_ssl: undefined
log: false
message: "Request canceled"
response: {…}
getHeader: function t()
options: Object { handleAs: "text", timeout: 180000, ioArgs: {…}, … }
url: "https://services2.arcgis.com/O6N5IYvqwiIIXKbZ/ArcGIS/rest/services/Bushaltestellen_Muenchen_OSM/Feat..."
xhr: XMLHttpRequest { readyState: 0, timeout: 0, withCredentials: false, … }
__proto__: Object { … }
responseText: undefined
stack: "f@https://js.arcgis.com/3.22/init.js:111:354
dojo/request/util/</b.deferred/r<@https://js.arcgis.com/3.22/init.js:135:327
Step 2 - Loading additional layers via Local Layer: NOK --> Afterwards I see the two additional layers in the Layer List, but grayed out, and i cannot work with them. And again error message(s):
_ssl: undefined
log: false
Step 3 - Creating a new Web app with OpenStreetMap and this feature Layer
is causing a different error:
"TypeError
columnNumber: 16
fileName: "https://js.arcgis.com/3.22/init.js"
lineNumber: 2061
message: "e is undefined"
stack: "_initLayer@https://js.arcgis.com/3.22/init.js:2061:16\
hitch/<@https://js.arcgis.com/3.22/init.js:63:275\
_initFeatureLayer@https://js.arcgis.com/3.22/init.js:2051:336
When invoking LLW again, our old friend "Request canceled" returns 😞
I recently faced similar issue in one of my old application.
Regards,
Prashant
A few of our Feature Service records are missing in the WAB attribute table widget. I am also getting "Request canceled" error.
{_ssl: undefined, description: "Request can...", dojoType: "cancel", log: false, message: "Request can...", name: "CancelError", response: Object {...}, responseText: undefined, stack: undefined........
Good afternoon, Markus Ehm1
I had a similar problem. In my case I use MapViewer. The MapViewer uses version 3.21(https://js.arcgis.com/3.21compact/) I changed it to 3.41 (https://js.arcgis.com/3.41compact/) and everything worked without problems.
Atte: HDRamosMendoza
Email: [email protected]
