Question on using the Editing Tools
4405
11
01-14-2013 07:47 AM
RobertWinterbottom
Hey Everyone, I have a question about the editing tools.  In my application I am using the template picker as well as the editing toolbar, in particular the reshape and cut tool. I am wondering what the best way to prevent the attribute inspector from appearing without interfering with any other tools.  For example I used the dojo.connect(myEditableLayer,"onClick") and called dojo.stop(evt) to prevent the default behavior from the onClick and stop the attribute inspector from popping up which works, but when I go to use the reshape tool I can't start inside the feature's geometry. What would be the best way to prevent the attribute inspector from being available to my user's?
KellyHutchins
Esri Notable Contributor
Robert,
Can you provide a code sample that shows the problem? You mentioned using the Template Picker and Draw Toolbar but not the Attribute Inspector. If you aren't using that then the attributes shouldn't appear - here's a sample that shows this:
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/ed_feature_creation
RobertWinterbottom
Thanks for the response Kelly.  I was looking for a little more functionality than what is in that sample.  I am looking to add in the editing toolbar as well which I took a screenshot of.  I would like to use this toolbar but not the attribute inspector. The code I am using for this is as follows:
       var settings = {
        map: map,
        templatePicker: templatePicker,
        layerInfos: [{featureLayer: editableLayer}],
        toolbarVisible: true,
        showAttributesOnClick: false,
        createOptions: {
         polygonDrawTools:[esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON,esri.dijit.editing.Editor.CREATE_TOOL_AUTOCOMPLETE]
        toolbarOptions: {
         reshapeVisible: true,
         cutVisible: true,
         selectVisible: false
       var params = {settings: settings};
       var myEditor = new esri.dijit.editing.Editor(params,"editingTools");
       myEditor.startup();
This seems to bring both the edit toolbar and the attribute inspector in, Is there a way to just get the edit toolbar?
Here is the screenshot of the edit toolbar I currently have and need to keep.
[ATTACH=CONFIG]20716[/ATTACH]
If you need me to post more code just let me know I can, There is a lot of code in the app and I did not want to post more than was necessary
KellyHutchins
Ok now I see. You are using the Editor widget which includes all the editing capabilities (template picker, toolbar, attribute inspector, attachments etc). One approach to this would be to build up the sample I sent earlier to add the additional capabilities. To do so you'd have to add a toolbar with buttons and associate them with the editor toolbar. See the sample here for details:
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/toolbar_edit
Another option that feels like a bit of a hack - but seems to work would be to hide the info window using css. To do this add the following to your app:
       .infowindow{
        visibility: hidden !important;
RobertWinterbottom
Thanks again Kelly.  I will try that tomorrow morning to see if I can get it working.  However I did not see any options on the sample page or the api reference page about adding in the Reshape Tool or the Cut tool, do you know of any way I could maybe add those to the toolbar in the same way as the other options in that sample?
RobertWinterbottom
Update on this.  Thanks for pointing out that sample Kelly, it looks like I can get most of the behavior I will be needing from doing that with the exception of the reshape and cut tool.  If there is a way I can add those to the toolbar that would be great.
On a separate note, I have noticed from doing some more testing that I am getting an error with the editor widget and was noticing the same error in one of the samples located here:
  http://help.arcgis.com/en/webapi/javascript/arcgis/samples/ed_simpletoolbar/index.html
The error is  - TypeError: 'undefined' is not an object (evaluating 'this._activeTool._enabled') and points to Editor-all.js line 19
This happens when I select a template from the template picker, then select the drawing tool I wish to use via this select widget (see attached photo).  Then if I move the mouse to the map I lose the tooltip and cannot draw. Upon selecting the template picker again I see this error and cannot draw any items on the map.  Everything works fine until I try to change the drawing tool.
[ATTACH=CONFIG]20731[/ATTACH]
KellyHutchins
Hi Robert,
The geometry service has cut and reshape operations so you can build a tool that calls the geometry service methods to perform the actions.
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#geometryservice
Thanks for the details about the error you are getting with the Editor. I'll take a look this morning and see if I can reproduce.
Kelly
RobertWinterbottom
Thanks for pointing that out Kelly, I will give it a shot.
RobertWinterbottom
Hey Kelly, I was curious if you were able to recreate that bug I had mentioned or if it seems like I may be doing something wrong on my end?
I had a meeting with my project manager the other day and it seems they really like the editor widget and would prefer I use that than building my own reshape and cut tool and connecting them to the geometry service. I was able to build a workaround for now by hiding the select box that was causing the error and placing a few buttons(one for each option that was in my select) in the toolbar that when clicked, will force the drawToolbar to activate a different drawing tool. This works for now but seems like kind of a hack.
KellyHutchins
Yes I was able to reproduce the problem and it is a bug in the JSAPI that we'll get fixed for the next release.
Kelly
