QueryTask Post vs Proxy
1007
04-28-2017 08:29 AM
thejuskambi
Hello,
Could someone explain to me when will QueryTask use POST request and when it will use Proxy?
I have two application, In one application when I use a complex buffered geometry to query it uses the proxy as expected and from documentation here. However, the second application does a POST request directly, when I use the same geometry. Both the application are intranet applications, hosted on the same web server and accessing services from same GIS Server. I am using js version 3.13.
The first application is a using legacy style while the other is AMD. Would this make a difference?
Any help is appreciated.
