QueryTask featureset grahics not showing on map.
1230
09-09-2014 06:48 AM
DanielNwankwo
I am performing a Query on a map service using the QueryTask.
I get the featureset back without problems. I can also add the features to the map however the graphic added to the map has no fill colour as I would see it if viewing with a dynamic service layer for example.
What am I missing?
I hope you understand the question?
RobertScheitlin__GISP
Daniel,
   Are you saying that you see the outline of the polygons and they do not have a fill or do you not see the polygons at all? Are you specifying a symbol for the graphics?
Daniel,
DanielNwankwo
I was seeing a faint white outline. I now realise it is the setup of the SimpleFillSymbol. Thank you for activating my brain.
