Query task not showing results
5997
11
10-27-2015 04:00 AM
SadanandacharB1
Hi All
I am doing query task using dojo and arcgis javscript,
but the result is not showing, there is no error, please help me, I am new to javascriptQueryTask.jpg
thejuskambi
Hello Sadananachar,
I think that is because of the scope of function. first you need to use this._map and not just _map. Second you need to ensure that the scope of the fuction is at module level. this can be achieved by using lang.hitch. For query task it should be something like this.
queryTask.execute(query, lang.hitch(this, this.showResults));
Also in your case you need to ensure that the function where you are setting up the query (_onSubmitClick)is also in the same scope. But In your case it seems to be ok as you are already using this.showResults. If it is not working then you need to hitch it to the right scope as well.
Thejus
SadanandacharB1
Hi thejus many many many many.... thanks to you, it solved my problem
