Query Related Records
1302
12-20-2010 12:49 PM
TrentReeder
Hello, I am trying to get the JS 2.1 Query Related Records sample script to work with some local data and I cannot get the related table records to show up.  I am using ArcGIS Server 10, JS 2.1 , ArcSDE 10, and SQL Server 2008.  The MapServer that I am referencing contains both a point feature class (0) and a table called Doc (1) with an associated 1:M relationship class.
The related fields are called FeatureID, so should this replace the OBJECTID in the code?  I've tried different scenarios with no luck.  I am pretty new to all this so it's probably a simple fix, but I've been staring at this for way too long.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <title>Query RelatedRecords Example</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dojox/grid/resources/tundraGrid.css">
    <style type="text/css">
        html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
        body {
          background-color:#777;
          overflow:hidden;
          font-family: "Trebuchet MS";
        #header {
          background-color:#444;
          color:orange;
          font-size:15pt;
          text-align:center;
          font-weight:bold;
        #footer {
          color:orange;
          font-size:10pt;
          text-align:center;
    </style>
    <script type="text/javascript">        djConfig = { parseOnLoad: true };</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
    <script type="text/javascript" language="Javascript">
        dojo.require("esri.map");
        dojo.require("esri.tasks.query");
        dojo.require("esri.toolbars.draw");
        dojo.require("dojox.color.Palette");
        dojo.require("esri.layers.FeatureLayer");
        dojo.require("dojox.grid.DataGrid");
        dojo.require("dojo.data.ItemFileReadStore");
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        var map, wellFeatureLayer, toolbar, grid, store, resizeTimer;
        function init() {
            var startExtent = new esri.geometry.Extent({ "xmin": -107.75, "ymin": 30, "xmax": -105, "ymax": 40, "spatialReference": { "wkid": 4269} });
            map = new esri.Map("mapDiv", { extent: esri.geometry.geographicToWebMercator(startExtent) });
            dojo.connect(map, "onLoad", initDocQueryFunctionality);
            var tiledLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            map.addLayer(tiledLayer);
            var imageParams = new esri.layers.ImageParameters();
            imageParams.layerIds = [0];
            imageParams.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW;
            var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis1ace/ArcGIS10/rest/services/MRG_query_test/MapServer", { imageParameters: imageParams });
            map.addLayer(dynamicLayer);
            var selectionSymbol = new esri.symbol.SimpleMarkerSymbol().setColor("red");
            pointFeatureLayer = new esri.layers.FeatureLayer("http://gis1ace/ArcGIS10/rest/services/MRG_query_test/MapServer/0", {
                mode: esri.layers.FeatureLayer.MODE_SELECTION,
                infoTemplate: new esri.InfoTemplate("Point", "<tr>Feature ID: <td>${FeatureID}</td></tr>")
            pointFeatureLayer.setSelectionSymbol(selectionSymbol);
            dojo.connect(pointFeatureLayer, "onSelectionComplete", findRelatedRecords);
            map.addLayer(pointFeatureLayer);
            dojo.connect(map, "onClick", findPoints);
        function initDocQueryFunctionality(map) {
            dojo.connect(dijit.byId('mapDiv'), 'resize', function () {
                resizeMap();
        function findRelatedRecords(features) {
            var relatedDocQuery = new esri.tasks.RelationshipQuery();
            relatedDocQuery.outFields = ["*"];
            relatedDocQuery.relationshipId = 1;
            relatedDocQuery.objectIds = [features[0].attributes.OBJECTID];
            pointFeatureLayer.queryRelatedFeatures(relatedDocQuery, function (relatedRecords) {
                var fset = relatedRecords[features[0].attributes.OBJECTID];
                var items = dojo.map(fset.features, function (feature) {
                    return feature.attributes;
                //Create data object to be used in store
                var data = {
                    identifier: "OBJECTID",  //This field needs to have unique values
                    label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                    items: items
                //Create data store and bind to grid.
                store = new dojo.data.ItemFileReadStore({ data: data });
                grid.setStore(store);
                grid.setQuery({ OBJECTID: '*' });
        function findPoints(evt) {
            grid.setStore(null);
            var selectionQuery = new esri.tasks.Query();
            var tol = map.extent.getWidth() / map.width * 5;
            var x = evt.mapPoint.x;
            var y = evt.mapPoint.y;
            var queryExtent = new esri.geometry.Extent(x - tol, y - tol, x + tol, y + tol, evt.mapPoint.spatialReference);
            selectionQuery.geometry = queryExtent;
            pointFeatureLayer.selectFeatures(selectionQuery, esri.layers.FeatureLayer.SELECTION_NEW);
        //Handle resize of browser
        function resizeMap() {
            clearTimeout(resizeTimer);
            resizeTimer = setTimeout(function () {
                map.resize();
                map.reposition();
            }, 500);
        dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <!--TOPMOST LAYOUT CONTAINER-->
    <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%; height:100%;">
      <!--HEADER SECTION-->
      <div id="header" dojotype="dijit.layout.ContentPane" region="top" style="height:75px;">
        Click on a well to select the well and select the related well log information for that well.
      </div>
      <!--CENTER SECTION-->
      <!--CENTER CONTAINER-->
      <div id="mapDiv" dojotype="dijit.layout.ContentPane" region="center" style="margin:5px;">
      </div>
      <!--RIGHT CONTAINER-->
      <div dojotype="dijit.layout.ContentPane" region="right" style="width:500px;margin:5px;background-color:whitesmoke;">
        <table dojoType="dojox.grid.DataGrid" jsid="grid" id="grid" rowsPerPage="5" rowSelector="20px" style="height:300px; width:300px">
          <thead>
            <tr>
              <th field="FeatureID">Feature ID</th>
              <th field="Title">Title</th>
              <th field="FileName">File Name</th>
              <th field="Description">Description</th>
            </tr>
          </thead>
        </table>
      </div>
    </div>
  </body>
  </body>
</html>
Please let me know if I left out anything.  Thanks for your help!
Trent
PauPérez_Puigcerver
You can make first an Identify to get value of the related field in the layer.
Then make a Query to the related table using the value returned in Identify
query.where = fieldName + "=" + value;
The table must be in the service (loaded in the .mxd).
Pau Pérez.
TrentReeder
Thanks Pau for your help!  I'll give it a try.
Forgot to mention that both the point and table features are in the .mxd that provides the services.
Trent
