Query point inside polygon
3366
10-15-2019 09:08 AM
ScottWilson2
I'm in a position where i have something working with the JavaScript API and now i'm trying to replicate it with the online Query Builder tool!
Here's my QueryTask which is successfully finding the point inside a polygon:
var residualWasteRequest = function(response, textStatus, xhr)
   var residualWasteRest = "https://myserver.com/external/rest/services/Map_Services/MapServer/0";
   var query = new Query();
   var queryTask = new QueryTask(residualWasteRest);
   query.outSpatialReference = { wkid: 102100 };
   query.where = "1=1";
   query.outFields = ["*"];
   query.returnGeometry = true;
   queryTask.execute(query, qtResponse);
function qtResponse(results) {
    var x = -488287.0574008291;
    var y = 7519911.928379749;
    var point = new Point(x, y, new SpatialReference({ wkid: 102100 }) );
    for (var item in results.features) {
        var polygon = results.features[item].geometry;
        if (polygon.contains(point)){
            console.log("point is inside a polygon: " +
            results.features[item].attributes.OBJECTID);
            map.centerAndZoom(point, 17);
Result:
point is inside a polygon: 18
Here's my equivalent query with the online tool:
I'm getting No records found.
What am i doing wrong?
thanks
Tags (1)
RobertScheitlin__GISP
Scott,
   Change Spatial Relationship to intersects.
Scott,
ScottWilson2
Hi Robert, changing Spacial Relationship to Intersects works a treat, thanks for your help
