Query Oracle table and map ArcGIS Javascript API
11159
15
12-05-2016 06:18 PM
AhmadSopian1
How to display layer the appropriate map query???
RobertScheitlin__GISP
Ahmad,
   Are you wanting to query Oracle directly without using ArcGIS Server?
AhmadSopian1
not, i'm using geodatabase n arcgis server Robert Scheitlin, GISP‌..
Ahmad,
   So do you have a map service published for this Oracle data then?
AhmadSopian1
Yes, I've map services published arcgis server n geodatabase connected oracle, so I do not know if I have a query or define that layer?
So, rscheitlin‌ get you to give me a solution n example...
Ahmad,
  Have you seen the Js API documentation? You need to add your layers using ArcGISDynamicMapServiceLayer or FeatureLayer. If you need limit the features for a layer than you can define a definition query in code. The API has many examples that you should begin looking at
AhmadSopian1
Can I use relationalship query in ArcGIS server ?, and I implement it in ArcGIS javascript API?
 function initOperationalLayer() {
              var infoTemplate = new InfoTemplate("${BD_ID}", "Building Name:  ${BD_NAME}", "Building Name:  ${BD_NAME}");
              var bdID = "BD_ID='PND_A' OR BD_ID= 'PND_J'";
              var featureLayer = new FeatureLayer("http://localhost/arcgis/rest/services/Demo/Demo/MapServer/0", {
                  mode: FeatureLayer.MODE_ONDEMAND,
                  outFields: ["*"],
                  infoTemplate: infoTemplate
              featureLayer.setDefinitionExpression(bdID);
Ahmad,
   Again relationship queries are covered in the JS API documentation:
RelationshipQuery | API Reference | ArcGIS API for JavaScript 3.18
AhmadSopian1
Thanks Robert Scheitlin, GISP, i've tried using relationalquery, but it has not yet completed my problem.
I want the layer to appear by year in the table, Can you refer to me..
Ahmad,
   Maybe sharing the code you have tried will help me understand what you are wanting to do.
