Query layer and return only the graphics selected
8209
20
06-27-2014 08:34 AM
AlexGole1
Hi all,
I am trying to create an application that allows users to query a layer and return only the graphics based on their selection, not only highlight the selected graphics.
Form instance, In my case, I want to query by users. As shown below I have a blue hashed polygon that represents Calmap users, in red I have "unknown users". My goal here is therefore to create a simple query that only returns the blue hashed polygon or red hashed polygon.
I have used this example but first it returns an error and also it will not return the exact same symbology as the feature layer I am using (is there a way to do that?).
  var gp, map, toc, dynaLayer1, query, queryTask;    var geocoder;       var symbol, infoTemplate, extractMethod;       var AOI, graphic, clipFeatureSet, clipFeature;       require(["dojo/_base/connect",          "dojo/dom", "dojo/dom-style", "dojo/parser", "dojo/on", "dojo/_base/Color",          "esri/map", "esri/config",          "esri/dijit/HomeButton",          "esri/dijit/BasemapGallery",          "esri/dijit/Bookmarks",          "esri/dijit/Scalebar",          "esri/geometry/Extent",          "esri/tasks/query", "esri/tasks/QueryTask",          "esri/layers/FeatureLayer",          "esri/layers/ArcGISTiledMapServiceLayer",          "esri/layers/ArcGISDynamicMapServiceLayer",          "esri/symbols/SimpleFillSymbol",          "esri/symbols/SimpleLineSymbol",          "esri/InfoTemplate",    "esri/tasks/FeatureSet",    "esri/graphic",          "agsjs/dijit/TOC",          "dijit/registry",          "dijit/layout/BorderContainer",          "dijit/layout/ContentPane",          "dijit/layout/AccordionContainer",          "dijit/TitlePane",          "dijit/form/CheckBox",          "dijit/form/ComboBox",          "dojo/parser",          "dijit/Toolbar",          "dijit/form/DropDownButton",    "dijit/layout/TabContainer",          "dijit/form/TextBox",          "dijit/TooltipDialog",          "dijit/ToolbarSeparator",          "dojo/domReady!"       ], function (connect, dom, domStyle, parser, on, Color,          Map, esriConfig, HomeButton, BasemapGallery, Bookmarks, Scalebar, Extent, Query, QueryTask, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,          SimpleFillSymbol, SimpleLineSymbol, InfoTemplate, FeatureSet, Graphic,          TOC, registry) {           // call the parser to create the dijit layout dijits          parser.parse(); // note djConfig.parseOnLoad = false;           // Specify where the location of the proxy to use to communicate with the extract GP service.          esriConfig.defaults.io.proxyUrl = "/proxy";            // Keep a reference to the loading icon DOM node.          var loading = dom.byId("loading");                     map = new Map("map", {             logo: true,             sliderPosition: "top-right",             basemap: "topo",             center: [-121.469, 38.556],             zoom: 8          });           var home = new HomeButton({             map: map          }, "HomeButton");          home.startup();           var basemapGallery = new BasemapGallery({             showArcGISBasemaps: true,             map: map          }, "basemapGallery");          basemapGallery.startup();                  var bookmarks = new Bookmarks({             map: map,             bookmarks: [],             editable: true          }, dom.byId('bookmarks'));           var scalebar = new Scalebar({             map: map,             // "dual" displays both miles and kilmometers             // "english" is the default, which displays miles             // use "metric" for kilometers             scalebarUnit: "dual",             scalebarStyle: "ruler",             attachTo: "bottom-left"          });           dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://webgisdevint1/arcgis/rest/services/Alex_Try/Archived/MapServer", {});           map.on('layers-add-result', function (evt) {             dynaLayer1.setVisibleLayers([1, 2, 4]);             toc = new TOC({                map: map,                layerInfos: [{                   layer: dynaLayer1,                   title: "Layers",                   slider: true                }]             }, 'tocdiv');             toc.startup();          });          map.addLayers([dynaLayer1]);            symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,             new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([111, 0, 255]), 2), new Color([255, 255, 0, 0.25]));          infoTemplate = new InfoTemplate("${OBJECTID}", "${*}");           registry.byId("query").on("click", executeQuery);           function executeQuery(name) {                 var name = document.getElementById("user").value       var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Archived/MapServer/0");             queryTask.on("complete", showResults)    var query = new Query();             query.returnGeometry = true;             query.outFields = ["LAST_EDITED_USER"];             query.where = "LAST_EDITED_USER = '" + name + "'";             query.outSpatialReference = map.spatialReference;             queryTask.execute(query, showResults);    }           function showResults(featureSet) {          //remove all graphics on the maps graphics layer          map.graphics.clear();           //Performance enhancer - assign featureSet array to a single variable.          var resultFeatures = featureSet.features;           //Loop through each feature returned          for (var i=0, il=resultFeatures.length; i<il; i++) {          //Get the current feature from the featureSet.          //Feature is a graphic          var graphic = resultFeatures;          graphic.setSymbol(symbol);           //Set the infoTemplate.          graphic.setInfoTemplate(infoTemplate);           //Add graphic to the map graphics layer.          map.graphics.add(graphic);         }        }
The error I get is:
"Cannot read property 'length' of undefined"
Thank you,
Alex
[ATTACH=CONFIG]34956[/ATTACH]
AlexGole1
Disregard the last message.
YungKaiChin
Your codes may have multiple problems, but first off, ...
Change from
queryTask.execute(query, showResults(featureSet) { alert(featureSet.length);});
To
queryTask.execute(query, function(featureSet) { alert(featureSet.length);});
Then, you can start from there.
AlexGole1
Change from
To
Ok. well same error.
http://testegis.fire.ca.gov/history_public/history_public.html
YungKaiChin
1. Did you see any popup with a number?
2. To limit other errors, you can comment all codes afterward.
AlexGole1
No nothing happens...
you can verify on my public app here:
http://testegis.fire.ca.gov/history_...ry_public.html
YungKaiChin
Sorry. Just found a mistake in my own code. 😛
It should be featureSet.features.length instead.
Nevertheless, if you don't see any popup, it means the problem is above that line of code.
TracySchloss
Honored Contributor
You shouldn't combine a queryTask.on('complete', showResults) with a queryTask.execute(query, function ....).  You have already specified your results handler, putting something different in the execute line just confuses things.
Also, if you execute with a listener on the 'complete' event, I believe the resultant output is generically 'results' and not a featureSet.  You end up having to change your code up slightly to get to the featureSet, something like
function showResults(results) {
var features = results.featureSet.features
Pay attention to what is really getting returned from your query handler, I don't think it's a featureSet.
AlexGole1
Ok,
I removed queryTask.on and modified the code as explained below but still get and error:
"results i not defined"
You can access my app modified here
Alex
TracySchloss
Honored Contributor
If you're going to remove the queryTask.on ('complete', handlerFunction),  and stick with queryTask.execute(query, handlerFunction) then you want to leave your showResults function as
function showResults(featureSet){ var features = featureSet.features;
If you want to want to go with
queryTask.execute(query, handlerFunction);
That's where you'd have your results function as
function showResults (results) { var features = results. featureSet.features;
I also think your for statement looks a little weird.  Maybe it should be
for (var i=0; i<features.length; i++){
AlexGole1
Thank you that was it! I just needed to remove query task.on.
Thanks again!
