query is undefined I built this code from this example page here on how to use a querytask. I changed the fieldname being used in the where clause because the field in the example doesn't exist. I tested my
3542
08-18-2014 12:01 AM
lasinh
<script type="text/javascript">
        require([
      "esri/map",
      "esri/layers/ArcGISDynamicMapServiceLayer",
     "dojo/dom",
       "dojo/on",
      "esri/tasks/QueryTask",
      "esri/tasks/query",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/InfoTemplate",
      "dojo/_base/Color",
      "dojo/domReady!"],
       function (Map,
        ArcGISDynamicMapServiceLayer,
         dom,
          on,
           QueryTask,
           Query,
           SimpleMarkerSymbol,
            InfoTemplate,
             Color,
             domReady) {
          map = new Map("map");
          var layer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
          map.addLayer(layer);
          var pop = dojo.byId('search-text').value;
          on(dojo.byId('search-button'), "click", executeQueryTask(pop));
          //initialize query task
          queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
          //initialize query
          query = new esri.tasks.Query();
          query.returnGeometry = true;
          query.outFields = ["CITY_NAME", "STATE_NAME", "POP1990"];
          //initialize InfoTemplate
          infoTemplate = new InfoTemplate("${CITY_NAME}", "Name : ${CITY_NAME}<br/> State : ${STATE_NAME}<br />Population : ${POP1990}");
          //create symbol for selected features
          symbol = new SimpleMarkerSymbol();
          symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
          symbol.setSize(10);
          symbol.setColor(new Color([255, 255, 0, 0.5]));
          function executeQueryTask(population) {
              //set query based on what user typed in for population;
              query.where = "POP1990 >"+ population;
              //execute query
              queryTask.execute(query, showResults);
          function showResults(featureSet) {
              //remove all graphics on the maps graphics layer
              map.graphics.clear();
              //Performance enhancer - assign featureSet array to a single variable.
              var resultFeatures = featureSet.features;
              //Loop through each feature returned
              for (var i = 0, il = resultFeatures.length; i < il; i++) {
                  //Get the current feature from the featureSet.
                  //Feature is a graphic
                  var graphic = resultFeatures;
                  graphic.setSymbol(symbol);
                  //Set the infoTemplate.
                  graphic.setInfoTemplate(infoTemplate);
                  //Add graphic to the map graphics layer.
                  map.graphics.add(graphic);
       </script>
DanPatterson_Retired
You title should be in the body of the message, it is far too long and not searchable.  Use appropriate tags to facilitate searching as well
lasinh
it is not work. query is undefinded
RobertScheitlin__GISP
Ia,
  In your code you never init a var called query. You have the proper require and the proper require alias for Query but you never var query in your code.
See line 24 on the code below.
        require([
      "esri/map",
    "dojo/dom",
      "dojo/on",
      "esri/tasks/query",
      "dojo/_base/Color",
      "dojo/domReady!"],
      function (Map,
        dom,
          on,
          QueryTask,
          Query,
          SimpleMarkerSymbol,
            InfoTemplate,
            Color,
            domReady) {
          var query, queryTask, infoTemplate, symbol;
          //initialize query
          symbol.setSize(10);
              //execute query
      </script>
