query from Geometry
6966
18
04-13-2020 10:33 AM
jaykapalczynski
Honored Contributor
  1. I am quering a FC for a specific field value
  2. Returning the Feature and displaying it in a Graphic.
  3. This works fine.
  4. I am  then attempting to do the same by calling another function to
  5. Use the Geometry of the Graphic to select all the COunty Features that Intersect it...
  6. THis part if failing and I cant see why.
Both FC are Web Mercator Aux Sphere
The Map is defined as follows ---- I think this defaults to Web Mercator Web Aux?
        var mapright = new Map({
            basemap: "dark-gray",
            layers: [resultsLayer3, resultsLayer2, countyLayerWebMercator]
        var viewright = new MapView({
            container: "viewDivright",
            map: mapright,
            center: [-77.05, 37.53308],
            zoom: 7
PART ONE query, get geometry create Graphic
        function queryMultipartPolyongUniqueID3(feature) {
            var str = feature;
            var query = "";
            query = MultiPartPolygonsLayer.createQuery();
            query.where = "ADDRESSgeo  = '" + str + "'";
            return MultiPartPolygonsLayer.queryFeatures(query);
// DISPLAY RESULTS IN GRAPHICS LAYER
        function displayResultsUniqueID(results) {
            resultsLayer2.removeAll();
            var features2 = results.features.map(function (graphic) {
                graphic.symbol = {
                    type: "simple-fill",
                    style: "solid",
                    color: [240, 248, 255, 0.9],
                    size: "10px", // pixels
                    outline: {
                        // autocasts as new SimpleLineSymbol()
                        width: 1 // points
                return graphic;
            var numCounties2 = features2.length;
            resultsLayer2.addMany(features2);
            // CALL THE SECOND FUNCTION
            queryCountiesthatIntersect().then(displayResults2);
THEN Call the second function at the end ----
1.  If I comment out the call to this 2nd function that code runs without error.
2.  If I run it with the call to the second function I get the below error.
ERROR
dojo.js:218 [esri.core.Accessor] Accessor#set Invalid property value, value needs to be one of 'esri.geometry.Extent', 'esri.geometry.Multipoint', 'esri.geometry.Point', 'esri.geometry.Polyline', 'esri.geometry.Polygon', or a plain object that can autocast (having .type = 'extent', 'multipoint', 'point', 'polyline', 'polygon')
QUESTIONS:
Am I getting this error because I am trying to use a Graphic Layer from the First Function Above?????
Can I use  graphic Layer?  If so do I need to define it differently?
Do I need to use a Feature Layer?
        function queryCountiesthatIntersect() {
            var query = countyLayerWebMercator.createQuery();
            query.geometry = resultsLayer2;
            query.spatialRelationship = "intersects";
            return countyLayerWebMercator.queryFeatures(query);
        function displayResults2(results) {
            resultsLayer3.removeAll();
            var features3 = results.features.map(function (graphic) {
                graphic.symbol = {
                    style: "solid",
                    outline: {
                        color: [191, 42, 18, 0.9],
                        width: 1 // points
                return graphic;
            var numCounties = features3.length;
            resultsLayer3.addMany(features3);
RobertScheitlin__GISP
That makes sense because the features var is an array of graphics.
Re-looking at your code  can you colsole.log(resultsLayer2.graphics) and make sure you have something there.
jaykapalczynski
Honored Contributor
jaykapalczynski
Honored Contributor
Both my datasets are Web Mercator Aux Sphere....
My map does not define a spatial reference....Could the Graphics be in a different projection and causing an issue?
jaykapalczynski
Honored Contributor
Looking at the console.log of the 1st Graphic Layer It appears to be in Web Mercator ....
Spatial Reference: 102100 / 3857
Why the heck cant I use this to query another FC with geometry and write that to a graphic...
Jay,
  Put an else in here and see if you can get a clue as to what is going wrong.
queryCountiesthatIntersect().then(displayResults2).else(function(err){
  console.log(err)
jaykapalczynski
Honored Contributor
Dosent give me anything...Add alert in there "In the Intersect" to make sure it was in the function
Nothing in the Console Error wise...
queryCountiesthatIntersect().then(displayResults2).else(function (err) {
console.log(err);
         console.log("In the Intersect");
          console.log(resultsLayer2.graphics);
Jay,
   Change.else to .catch
queryCountiesthatIntersect().then(displayResults2).catch(function (err) {
console.log(err);
jaykapalczynski
Honored Contributor
Thanks Robert Scheitlin, GISP‌ for steering me in the right direction......much appreciated.
jaykapalczynski
Honored Contributor
I got it with this: i was missing the "items"
query.geometry = resultsLayer2.graphics.items[0].geometry;
NOT
query.geometry = resultsLayer2.graphics[0].geometry;
I had to walk the console.log of the Graphics layer a bit more
