query from Geometry
6770
18
04-13-2020 10:33 AM
jaykapalczynski
Honored Contributor
  1. I am quering a FC for a specific field value
  2. Returning the Feature and displaying it in a Graphic.
  3. This works fine.
  4. I am  then attempting to do the same by calling another function to
  5. Use the Geometry of the Graphic to select all the COunty Features that Intersect it...
  6. THis part if failing and I cant see why.
Both FC are Web Mercator Aux Sphere
The Map is defined as follows ---- I think this defaults to Web Mercator Web Aux?
        var mapright = new Map({
            basemap: "dark-gray",
            layers: [resultsLayer3, resultsLayer2, countyLayerWebMercator]
        var viewright = new MapView({
            container: "viewDivright",
            map: mapright,
            center: [-77.05, 37.53308],
            zoom: 7
PART ONE query, get geometry create Graphic
        function queryMultipartPolyongUniqueID3(feature) {
            var str = feature;
            var query = "";
            query = MultiPartPolygonsLayer.createQuery();
            query.where = "ADDRESSgeo  = '" + str + "'";
            return MultiPartPolygonsLayer.queryFeatures(query);
// DISPLAY RESULTS IN GRAPHICS LAYER
        function displayResultsUniqueID(results) {
            resultsLayer2.removeAll();
            var features2 = results.features.map(function (graphic) {
                graphic.symbol = {
                    type: "simple-fill",
                    style: "solid",
                    color: [240, 248, 255, 0.9],
                    size: "10px", // pixels
                    outline: {
                        // autocasts as new SimpleLineSymbol()
                        width: 1 // points
                return graphic;
            var numCounties2 = features2.length;
            resultsLayer2.addMany(features2);
            // CALL THE SECOND FUNCTION
            queryCountiesthatIntersect().then(displayResults2);
THEN Call the second function at the end ----
1.  If I comment out the call to this 2nd function that code runs without error.
2.  If I run it with the call to the second function I get the below error.
ERROR
dojo.js:218 [esri.core.Accessor] Accessor#set Invalid property value, value needs to be one of 'esri.geometry.Extent', 'esri.geometry.Multipoint', 'esri.geometry.Point', 'esri.geometry.Polyline', 'esri.geometry.Polygon', or a plain object that can autocast (having .type = 'extent', 'multipoint', 'point', 'polyline', 'polygon')
QUESTIONS:
Am I getting this error because I am trying to use a Graphic Layer from the First Function Above?????
Can I use  graphic Layer?  If so do I need to define it differently?
Do I need to use a Feature Layer?
        function queryCountiesthatIntersect() {
            var query = countyLayerWebMercator.createQuery();
            query.geometry = resultsLayer2;
            query.spatialRelationship = "intersects";
            return countyLayerWebMercator.queryFeatures(query);
        function displayResults2(results) {
            resultsLayer3.removeAll();
            var features3 = results.features.map(function (graphic) {
                graphic.symbol = {
                    style: "solid",
                    outline: {
                        color: [191, 42, 18, 0.9],
                        width: 1 // points
                return graphic;
            var numCounties = features3.length;
            resultsLayer3.addMany(features3);
jaykapalczynski
Honored Contributor
I got it with this: i was missing the "items"
query.geometry = resultsLayer2.graphics.items[0].geometry;
NOT
query.geometry = resultsLayer2.graphics[0].geometry;
I had to walk the console.log of the Graphics layer a bit more
jaykapalczynski
Honored Contributor
Funny thing is I get this error but the 2nd function still displays data but for some reason ALL of the County data....not the ones that are intersecting the Graphic Layer.  So I am assuming I might have to define the Geometry of the Graphic Layer?
RobertScheitlin__GISP
Jay,
  The queries geometry property has to be a single geometry. You are currently attempting to pass a GraphicsLayer with possibly multiple graphics.
jaykapalczynski
Honored Contributor
query.geometry = resultsLayer2.geometry[0];  ????
jaykapalczynski
Honored Contributor
Tried this and don't get to the second alert
   alert("1");
   alert("2");
jaykapalczynski
Honored Contributor
I changed the Graphic build to this as well
            resultsLayer2.add(features2);
NOT
Jay,
 addmany would look like this. it is expecting an array.
resultsLayer2.addMany([features2]);
jaykapalczynski
Honored Contributor
This works fine and I get the 1st function to render the graphic layer properly
This does NOT work...the graphic layer in the first function does not draw.
Still think there is an issue with this...when trying to use the geometry to find the counties that intersect the Graphic Layer
written like this I get nothing
written like this I get all 133 counties
jaykapalczynski
Honored Contributor
I was using this ESRI Example:  ArcGIS API for JavaScript Sandbox
towards the bottom
function displayResults(results) {
resultsLayer.removeAll();
var features = results.features.map(function(graphic) {
graphic.symbol = {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
style: "diamond",
color: "darkorange"
return graphic;
var numQuakes = features.length;
document.getElementById("results").innerHTML =
numQuakes + " earthquakes found";
resultsLayer.addMany(features);
