Query features in the View on the client when feature is off screen
2314
02-28-2023 12:38 PM
GregoryBologna
I have a buffer featureLayer query that does not return features if part of the buffered area in the view is off screen. How can I get buffer results in this situation? Thanks.
What is meant by "available to or visible" here in the documentation?  I always want to return available regardless of visibile.
To query features/graphics available to or visible in the View on the client rather than making a server-side query, you must use the FeatureLayerView.queryFeatures() method.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#queryFea...
Here's my procedural code fragment.
Step 1. Create queryFeatureLayer
    const queryFeatureLayer = new FeatureLayer({
      url: url,
      geometryType: 'polygon',
      title: 'myfeatureLayer',
      spatialReference: {
        wkid: 102659,
      outFields: [
        'OBJECTID',
	and others...
Step 2. Wait for global object mapLayerView to be ready then run queryLayerView()
    reactiveUtils
     .whenOnce(() => !mapLayerView.updating)
     .then(() => {
       queryLayerView();
Step 3. Execute the queryLayerView
const queryObject = mapLayerView.createQuery();
queryObject.geometry = sketchGeometryMode();
queryObject.units = unitType;
queryObject.distance = bufferSize;
queryObject.spatialRelationship = 'intersects';
queryObject.outSpatialReference = view.spatialReference;
queryObject.returnQueryGeometry = true;
queryObject.returnDistinctValues = true;
queryObject.outFields = ['*'];
Step 4. Get results
return mapLayerView
  .queryFeatures(queryObject)
  .then((layerView) => { ... }
GregoryBologna
Thank you. Your answer indeed solves the drawback to client-side buffering. I made the change and it works well, performance is close to client-side with some minor noticeable delay in the buffer polygon. I also had enable returnGeometry and remove returnDistinctValues because it's not supported with it. I am curious to know why "queryFeatures" throws an error "TypeError: Cannot read properties of undefined (reading 'featureResult')" after several continuous queries are made. Basically, after a few queries, the response from ArgGIS server is empty and results in the error above. The error doesn't prevent subsequent queries, but I decided to handle the error by detecting it and continuing. Has to be a better way.
Sage_Wall
Hi @GregoryBologna ,
The LayerView is responsible for rendering the layer in your map view and it contains only the necessary information draw the symbols. The LayerView likely doesn't contain all the features in your layer, but only a subset of the features based on what features are currently visible in the map view.  When you are querying the layer view and your buffer goes beyond the view's extent those features aren't guaranteed to be loaded into the layer view.
You would want to do a server-side layer query to return the results properly.  The layer query will return all the results that satisfy the query parameters regardless of whether they are visible in your browser.  Simply switching to querying your 'queryFeatureLayer' instead of your 'mapLayerView' should give you the results your expecting.
      url: url,
      spatialReference: {
        wkid: 102659,
      outFields: [
        'OBJECTID',
	and others...
Step 2. Execute the query
const queryObject = queryFeatureLayer.createQuery();
queryFeatureLayer
  .then((featureSet) => { ... }
GregoryBologna
Sage_Wall
I'm glad it's mostly working. The error is unexpected. Do you have access to the ArcGIS Server logs? There might be something going on server side with data access.
