query feature layer date field
638
08-04-2022 03:14 AM
GuyShaharabani
I'm trying to query a feature layer by a date field, and there is a problem with the 'less then' operator.
it is not a code problem, I'm trying to query in the feature layer rest.
this query works:
CreatedTime > TIMESTAMP '2022-01-01 15:30:00'
but this query does not:
CreatedTime < TIMESTAMP '2022-01-01 15:30:00'
this is the field:
and just to be clear.. there are rows that match both conditions.
I Don't know if this has anything to do with it but this is the SQL field:
I've tried to use between, sometimes it works and sometimes it doesn't(working example):
CreatedTime Between TIMESTAMP '2022-07-28 00:00:00' AND TIMESTAMP '2022-07-28 23:59:59'
 an example of a query that have no results, that does have results in sql server:
CreatedTime Between TIMESTAMP '2021-07-01 11:00:00' AND TIMESTAMP '2022-07-06 11:00:00'
