Query Feature and Zoom
5273
12
01-06-2012 02:05 PM
CarlSunderman1
I've searched here and the rest forums and can't seem to find an answer.
I have a php page that when a value is click, a fancybox iframe opens with data, a floor plan, and a map of the building. i have passed the variable to javascript but am unable to see how to pass the variable to the map to zoom to the feature(QueryTask?). i've tried using query?where= but i seem to be way off. i've looked into the QueryTask, but have been unable to find an example of what i'm trying to accomplish. Does anyone have an example i can look at?
StephenLead
Honored Contributor
Hi Carl,
Can you provide further information - which variable are you passing to the map? Have you configured a query and querytask?
Can you provide a link to your site, or some sample code?
Steve
CarlSunderman1
Unfortunately, our server is on our intranet. I'm passing the objectid value to js Is a query task really needed? there is no other way to pass the value?  the query tasks i have seen seem to be more related to the data table and i can't seem to find a simple example of passing a variable to the query task to pan and zoom
i did find this:
function zoomRow(id){
      selectionLayer.clear();
      dojo.some(map.graphics.graphics,function(graphic){
        if (graphic.attributes.ObjectID.toString() === id) {
          var selectedState = new esri.Graphic(graphic.geometry).setAttributes(
              graphic.attributes);
          selectionLayer.add(selectedState);
          var stateExtent = selectedState.geometry.getExtent().expand(5.0);
          map.setExtent(stateExtent);
          return true;
here http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2009/12/14/Add-a-Zoom-button-to-a-DataGrid.aspx
which basically does what i want, i just need to do an onload, i think
StephenLead
Honored Contributor
The sample you referenced may not be perfectly suited to your task - it's passing in the OBJECTID of the feature, then iterating through each graphic on the map to see whether its ID matches. It then zooms to the matching graphic.
Another approach is to run a query, then zoom to the extent of the feature(s) which are returned. Assuming that you know the OBJECTID (or some other unique attribute) of your feature, you could use something like this:
//Define a new Query and QueryTask
queryTask = new esri.tasks.QueryTask(UrlToYourLayer);
query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["field1","field2"];
//The query's where clause will be attribute query to find the feature
query.where = "'OBJECTID = 123'";
//Run the query. Its results are returned in the function showResults
queryTask.execute(query,showResults);
//results is an array of any found features. Assuming you only want the first feature:
function showResults(results) {
    var result = results[0];
    var extent = result.geometry.getExtent().expand(5.0);
    map.setExtent(extent);
(Note that I haven't actually tested this so it's more of a conceptual overview.)
Cheers,
Steve
CarlSunderman1
Thanks stevel
With outfields populated i get a
"dojo.io.script.jsonp_dojoIoScript1._jsonpCallback({"error":{"code":400,"message":"Unable to complete  operation.","details":["Unable to complete Query operation."]}});" error
with outfields empty i get
"TypeError: Cannot read property 'geometry' of undefined {}"
regardless, the map errors and doesn't draw
<script type="text/javascript">
  dojo.require("esri.map");
  dojo.require("esri.tasks.query");
   function init() {
    map = new esri.Map("mapDiv");
    var basemapURL= "http://<myserver>/ArcGIS/rest/services/<myservice>/MapServer"
    var basemap = new esri.layers.ArcGISDynamicMapServiceLayer(basemapURL);
    map.addLayer(basemap);
    // sample Query Task
    // define variables
     var queryTask, query;
    queryTask = new esri.tasks.QueryTask("http://<myserver>/ArcGIS/rest/services/<myservice>/MapServer/7");
    query.outFields = ["BUILDNG_NO","ADDRESS_ID"];
query.where = "OBJECTID=6742";
    // end of Query Task
  dojo.addOnLoad(init);
</script>
StephenLead
Honored Contributor
You know how I said I hadn't actually tested that code? There were a couple of typos in there. The showResults section should look something like this:
  var result = results.features[0];
  map.setExtent(esri.geometry.geographicToWebMercator(extent));
The key missing thing was results.features[0], to obtain the first feature in the results.
You may also need to translate the extent from geographic coordinates to web mercator, depending on your datasets (as in the attached demo, which zooms to the extent of a polygon on opening. That's because the query uses a dataset specified in decimal degrees, while the basemap is in Web Mercator.)
Cheers,
Steve
CarlSunderman1
Stevel
  thanks, That's exactly what i needed
Carl
StephenLead
Honored Contributor
Cool, glad you got it sorted.
The first sample was pretty dodgy - it loaded the map then immediately ran the query, which isn't very useful.
In case anyone reads this thread later, attached is a more useable version. It waits for the user to enter a query string, then runs the query when the user hits the Query button.
If you step through it in FireBug you can see what's happening.
Cheers,
Steve
ChristopherPollard
Steve,
Thanks so much for the query sample code.
I have a mapping application that I need to zoom to ALL the features returned, not just the 1st feature.
I tried to modify your sample but was not getting anywhere.
Any help would be appreciated.
Chris
StephenLead
Honored Contributor
I need to zoom to ALL the features returned, not just the 1st feature. I tried to modify your sample but was not getting anywhere.
See the section:
  //This function is run when the query has finished.
  //It zooms the map to the extent of the first feature returned by the query.
You'll want to iterate through each feature and union the extent so that it expands to include all features. Pseudo-code is:
var fullExtent;
for each result in results:
  thisExtent = result.geometry.getExtent();
  fullExtent.union(fullExtent);
I haven't tested this, so you might need to initialise fullExtent as the extent of the first feature, before union-ing it with all of the other features' extents.
Good luck,
Steve
