Qlik Sense - Esri Integration (Esri Extension)
3647
06-04-2018 11:35 PM
Sundhar_RajT
I have integrated esri webmap with qlik sense using arcgis javascript api 3.8. I have downloaded the source code from github.
Now, i want to migrate it to arcgis javascript api 4.7. But, map is not loading. getting invalid visualisation error. Herewith i have attached my code.
require.config({
paths: {
"components": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components",
"dojo": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components/dojo", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components/dojo",
"dijit": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components/dijit", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components/dijit",
"dojox": "https://rawgit.com/johsund/QlikESRIGit/master/bower_components/dojox", //"http://localhost:4848/extensions/QlikSenseESRI/bower_components/dojox",
//"esri": "https://js.arcgis.com/3.8/js/esri"
"esri": "https://js.arcgis.com/4.7/esri"
define( [
'jquery',
'text!./template.html',
'text!./css/esri.css',
'qvangular',
'js/qlik',
"esri/views/MapView",
"esri/WebMap",
"dojo/_base/Color",
"dojo/_base/array",
"dojo/dom",
"dojo/on",
"dojo/domReady!"
], function ( $, template, cssContent, qv, qlik, MapView, WebMap, Color, arrayUtils, dom, on) {
'use strict';
$("<style>").html(cssContent).appendTo("head");
//Legend widget
var legendDijit, position;
return {
paint: function ( $element, layout ) {
// GETTING THE DATA FROM Qlik
this.backendApi.cacheCube.enabled = false;
var _this = this;
var columns = layout.qHyperCube.qSize.qcx, totalheight = layout.qHyperCube.qSize.qcy;
var pageheight = Math.floor(10000 / columns);
var numberOfPages = Math.ceil(totalheight / pageheight);
var markers = [];
var selectedMarkers = [];
var dimensions = layout.qHyperCube.qDimensionInfo;
var columns = layout.qHyperCube.qSize.qcx;
var totalheight = layout.qHyperCube.qSize.qcy;
var Promise = qv.getService('$q');
var promises = Array.apply(null, Array(numberOfPages)).map(function(data, index) {
var page = {
qTop: (pageheight * index) + index,
qLeft: 0,
qWidth: columns,
qHeight: pageheight
return this.backendApi.getData([page]);
}, this)
$element.html(template);
Promise.all(promises).then(function(d) {
render(d);
function render(d) {
var webmap = new WebMap({
portalItem: { // autocasts as new PortalItem()
var view = new MapView({
map: webmap,
container: "mapDiv"
var map = new Map({
basemap: "topo"
container: "mapDiv",
map: map,
scale: 2400000
}; //render
} //paint
Please help me to migrate to arcgis javascript api 4.7
JorgeAmirola
Hi Raj, do you the the qlik sense esri entension for the new version qliksense? i downloaded the file from github and they said it's for version 2.1.   I am wondering do you have the newest one?
sreekantamanuru
With reference to above code, I used CDN network ESRI ArcGIS javascript 3.27, dojo and moment files, i am facing below error. While just adding Api - esri/map and Map alias, i got this error. In web browser, network all ESRI modules are downloading. Please help me to resolve this error. Currently i am using Qlik Sense Desktop - 14.54.15 (with custom objects)
Sample Code given below:
{/* <script src="/node_modules/requirejs.js"></script> */}
window.require.config({
    baseUrl: "/node_modules",
    async:true,
    paths: {
        //"esri": "https://js.arcgis.com/3.27/esri",
        "esri": "https://js.arcgis.com/3.43compact/esri",
        "moment": "https://js.arcgis.com/3.27/moment",
    parseOnLoad: false,
    //waitSeconds: 15
define(["jquery", "text!./template.html", "text!./cssContent.css","qvangular", "qlik","esri/map"],
function($, template, cssContent, qv, qlik,Map) {
// define(["jquery", "text!./template.html", "text!./cssContent.css","qvangular", "qlik","esri/map","dojo/_base/array","dojo/dom","dojo/on","dojo/ready"],
// function($, template, cssContent, qv, qlik,Map, arrayUtils, dom, on) {
    'use strict';
    console.log("Map");
    var init = false;
    return {
        template : template,
        initialProperties : {
            qHyperCubeDef : {
                qDimensions : [],
                qMeasures : [],
                qInitialDataFetch : [{
                    qWidth : 2,
                    qHeight : 50
        definition : {
            type: "items",
            component: "accordion",
            items: {
                dimensions: {
                    uses: "dimensions",
                    min: 1,
                    max: 1
                measures: {
                    uses: "measures",
                    min: 1,
                    max: 1
                sorting: {
                    uses: "sorting"
                settings: {
                    uses: "settings",
                    items : {
                    webmapid : {
                            ref : "webmapid",
                            type : "string",
                            label : "Web map ID",
                            defaultValue : "62e89135fcc8461bbe2ba6c7b152d14a"
                            //defaultValue : "891937e148e7482caef8671fdc22515b"
        support : {
            snapshot: true,
            export: true,
            exportData : true
        paint: function ($element,layout ) {
        //paint: async function ($element,layout ) {
            console.log( $element );
            console.log( layout );
            $element.empty();
            //adding
            var _this = this;
            console.log("before promise");
                var page = {
                    qLeft: 0,
                    qWidth: columns,
                    qHeight: pageheight
            }, this);
            // Promise.all(promises).then(function(d) {
            //  //render(d);
            //  console.log("inside promises");
            //adding
            // var app = qlik.currApp(this);
            // app.clearAll();
            // var map={};
            //if ( !$element.html.empty ) {
                //$element.empty();
                $element.html( template );
                //$element.appendTo( template );
                //app.$element.html( app.esri.Map );
                //qlik.Map($element.appendTo( template ));
                //await qlik.$element.html( template );
                console.log( "maploaded " );
            Promise.resolve().then( function(d) {
                map = new Map("mapDiv", {
                    basemap: "topo-vector",
                    center: [-122.45, 37.75],
                    zoom: 13
                console.log( "zoom -- " + map.zoom );
            console.log("before promises");
            if (!init) {
                return new Promise(function(resolve, reject) {
                    setTimeout(function() {
                        var map = new Map($element[0], {
                            zoom: 13
                        resolve(); // Extension painted successfully
                    }, 1000);
                // Mark initial setup complete
                init = true;
                // var map;
                var app = qlik.currApp();
                // var map = new Map("mapDiv", {
                //  basemap: "topo-vector",
                //  center: [-122.45, 37.75],
                //  zoom: 13
                // console.log( map.zoom );
                console.log( app );
            //return qlik.Promise.resolve();
        controller : ['$scope',
        function(/*$scope*/) {
