Proxy specific map services instead of all map services
1156
03-19-2012 03:10 PM
DanielLi
For my map viewer, I am using a proxy page with token authentication. When I set "alwaysUseProxy=true", every time i add a map service as a new layer to my base map, the proxy page is called. Is there a way to proxy specific map services instead of all of them?
Here is a scenario: if I want my base map to use a map service from my ArcGIS server, then my map viewer should call the proxy page to retrieve a token so it can display the base map. Then I want to add a layer using a map service from ArcGISOnline. During this event, I do not want the proxy page to get called. After that, I want to add another layer using a map service from my ArcGIS server. This means that the proxy should get called again to retrieve another token.
Please let me know if this is possible.
nicogis
your services pass to proxy ( esri.config.defaults.io.alwaysUseProxy = true; it is need if you have service protect) but in proxy you decide what do you want to do (if service isn't protect you don't need ask a token).
