proxy error on Error: Unable to load proxy.ashx
8247
5
02-13-2011 05:38 PM
by Anonymous User
Not applicable
Hi there
I tried to copy the edit sample which provided by ESRI.
As required, I changed the proxy address and point to my local proxy address.
Unfortunately I got "Error: Unable to load http://localhost/test/proxy.ashx?http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/She... status:500
Line 0"
The proxy files just downloaded from ESRI and had been add for http://sampleserver3.arcgisonline.com/....
Any idea?
Regards,
Bing
HaroldBostic
Hi there
Line 0"
Any idea?
Regards,
Bing
Did you ever find the resolution to this issue?
RichardWatson
I do not quite understand the target for the proxy, i.e.
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/2/applyEdits
I believe that there is some information missing at the end of this URL, i.e. the feature data.
Regardless, one trick to try if you are having proxy problems is to just bypass the proxy and see if it works.
shwetakunjadia
You got the solution??
I am having same prob with proxy.jsp 😞
Shweta
nicogis
MVP Alum
Open proxy.ashx with Visual studio and debug your url (http://localhost/test/proxy.ashx?htt...r/2/applyEdits) so you can check your problem
DavidHollema
