Proxy.ashx problem
10287
03-11-2014 05:22 AM
manvinderkandhari
I downloaded source from  http://github.com/Esri/resource-proxy   for .net. My proxy.config is simple
<ProxyConfig   mustMatch="false">
    <serverUrls>
      <serverUrl url="http://services.arcgisonline.com"     matchAll="true"  />
      <serverUrl url="http://server.arcgisonline.com"     matchAll="true"  />
    </serverUrls>
</ProxyConfig>
Problem i am having is when i test my proxy ,it retrieves the info/data from the given URL but path for all .css ,image files is relative to my local machine.
My request looks like :http://local.XYZ.com/wewportal/proxy.ashx?http://server.arcgisonline.com
error i see in Firebug :"NetworkError: 404 Not Found - http://local.xyz.com/arcgis/rest/static/main.css"
my website is in MVC4 and proxy.ashx,proxy.config are in the root directory.Am i missing some setting on IIS ?
Thanks
Manvi
JesseAdams
Did you find a resolution to this issue?  I'm experiencing the same issue when trying to run a localhost proxy to a remote ArcGIS Server.  If I put the same configuration on one of our servers to works without an issue.  Would be great if development on localhost would work the same way.
BjornSvensson
Esri Alum
The proxy isn't intended to re-write the content of the proxied request to update relative links to css or images.
While this does make it a bit ugly in your screenshot (when testing it in the browser), do you have a problem when using the proxy in your application?  If so, could you tell us more about how you are using the proxy?
Thanks 🙂
BjornSvensson
Esri Alum
Jesse, I'm not sure I understand.  Are you saying the proxy works different on one machine than another? Or that it behaves differently when proxying one server than another?
